220 volts Versus 120 volts
donskister
Nov 22, 2006
21
1. Hi guys! i noticed that every countries have their different voltages supply..in my country we used 220volts other countries used 120volts... im just confused can u pls enlighten me...what is more economical to used 120v or 220v? advantages & disadvantages using 120V or 220V? We all know a TV that was manufactured at Japan having 120v can used to other country that have 220V using step up transformer...
2. I saw lately my friend have a halogen bulb w/ the specifications of 24Volts ac 5Owatts, the problem is he told me that the store he used to buy that bulb are out stock only available are 22.8Volts ac 50 watts...This will be used at the OR lights ( heraeusHanaulux ) ...im just confused! that the reason i come out w/ my question no. 1..What is the reason of having different voltages used to light up a bulb having a 50 watts:Is there any effect in intensity of the lights and operation of the equipments? confuse: .....By the way in our countries we used 220volts ac.
3. 220volts versus 120volts .........
audioguru2
Apr 6, 2004
12,022
Hi Don,
I am in Canada where we have both 120VAC and 240VAC in our homes. Most things work with 120VAC but high power appliances like the stove, air conditioning and clothes dryer use 240V.
Your halogen light bulb is 22.8V or 24V and they are only 5% different so either bulb will work fine. The 22.8V bulb will be a little brighter and will burn out a little sooner with 24V.
donskister
Nov 22, 2006
21
Thanks for the advice....its highly appreciated sir....we will  install it..So we can record the  life span of the bulb having 22.8v in the unit...
thakns sir
prateeksikka
Jun 19, 2004
736
hi audioguru!
can i run my 220V indian device in Canada where 120V is the mains supply or like wise in any other country where we have only 120V?
is a step down transformer enough for this?
bobleny
Oct 3, 2006
141
Like Canada, U.S. also uses both ~220 and ~110. We use the 220 to power big stuff that need a lot of power such as a stove, water furnace, washer dryer, etc...
In the U.S. we are charged by kilowatt hour. Which means, if we use the same amperage at 220, we will be charged a lot more! I would image that a device will be drawing the same amount of current at 110 or 220, provided that it can run at both voltages.
So, the disadvantage to 220, is that it will most likely coast more, however, you can run more powerful toasters off of 220...
audioguru2
Apr 6, 2004
12,022
So, the disadvantage to 220, is that it will most likely cost more, however, you can run more powerful toasters off of 220...
No. A device that operates with both voltages will draw the same power with either voltage, so the current is half when the voltage is doubled. Then the cost of the electrical power is the same.
My toaster gets pretty hot. If its power is doubled then it would set itself and my house on fire!
audioguru2
Apr 6, 2004
12,022
You forgot in your calculation that countries with 220V mains charge much more for electricity and all other forms of power (gasoline, for example) than the very cheap power in Canada and the US.
ante1
Jan 24, 2004
4,136
Hi AG,
I think you got it reversed here, with 230V it’s cheaper because the power companies can use half the wire gauge for the same kWh and the transmission losses are less with higher voltage.
From where I see it $0.07 / kWh is not cheap! :eek:
audioguru2
Apr 6, 2004
12,022
Hi Ante,
I am paying only about $.10/kWh. Sure it is cheap. It would be a lot cheaper if Canada was smaller because I am subsidizing the people who live hundreds of km from a generating station. Niagara Falls is not far from me.
ante1
Jan 24, 2004
4,136
audioguru said:
Hi Ante,
ONLY! :eek:  Are you kidding?
Here we have 3 phase 400V for heavy appliance (stove, washing machine or a welder) and 230-240V for everything else this allows thinner wiring and lower losses (but slightly bigger transformers since we have only 50Hz)! ;D
audioguru2
Apr 6, 2004
12,022
Hi Ante,
My electricity is cheap because I don't waste it like many people do. A neighbour pays more than 4 times as much as me. Their incandescent lights are on all the time when I have only one to four compact fluorescent lights turned on only when needed. Their air conditioning is on when a nice cool breeze blows through open windows on my house. Their clothes dryer is going when my clothes are drying on the line outside.
Pretty soon my electricity supplier will charge a premium price for electricity that is used at at times of peak demand. I will avoid consumption at those times then I will pay less than now.
donskister
Nov 22, 2006
21
Hi ante..
Thanks for the information about the economical point of view regarding to the wire needed when you have higher voltage which allow thinner wiring compare to low voltage, ..Can you give me mathematical computation with that...what about regarding to transmission losses can you also give me mathematical explanation..
You also mentioned
ante1
Jan 24, 2004
4,136
Hi Don,
Basically it’s P = U * I .
The transformer puts up a higher resistance at a higher frequency which means fewer turns of wire thus a smaller transformer.
Kevin Weddle
Feb 23, 2004
1,620
I believe you can take (2) out of phase sinewaves to make 220Vac. Anybody ever done this? Or do all houses come with a 220Vac line?
audioguru2
Apr 6, 2004
12,022
Hi Kevin,
I have 120VAC mains in Canada for most electrical receptacles, but my stove, clothes dryer and air conditioning operate from the 240V that is in my home. It is one 120VAC phase and neutral and an opposite 120VAC phase and neutral. The neutral is connected to ground.
