24Cxxx I2C EEPROM
O
Octavio
Looking at few datasheets, I can't tell if these small EEPROM chips have
internal ESD protection diodes to Vcc and to ground.
Do they have these ESD protections?
Octavio
Donald
Octavio
I don't think I have ever seen an 24c device with ESD protection.
But then again, I don't think I would ever connect a 24c device in a way
that ESD would ever get to it.
ESD concerns implies you want the part connected to the outside world
somewhere !!
Why would you do that ??!!
donald
Eeyore
You didn't look very far did you ?
• ESD protection > 4,000V
From Microchip data on the 24C08 for example.
This is for ESD protection during handling / assembly only btw.
Graham
Spehro Pefhany
Octavio
Almost always CMOS chips have such diodes. Failing that, some other
kind of protection structure on the inputs, or they might never make
it through the assembly process.
You can usually tell from the electrical characteristics.. absolute
maximum ratings for inputs and outputs. If it's Vdd + X where X is
around a diode drop, you have your answer.
Best regards,
Spehro Pefhany
Michael A. Terrell
How do you think your computer knows what monitor you're using?
Several lines to a 24CxxxEEPROM are exposed at the HDE-15 connector.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Donald
I'll have to open my monitor and find out. ;-)
Michael A. Terrell
There are plenty of schematics online.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Donald
Graham
I looked at Atmel 24C08 and 24C32.
http://www.atmel.com/dyn/resources/prod_documents/doc0180.pdf
http://www.atmel.com/dyn/resources/prod_documents/doc0336.pdf
One data sheet for the 24C08 did say ESD to 4000V,
however the 24C0x and 24C32 datasheets from the Atmel site never
mentions ESD.
go figure
donald
