24v 300w power supply
  • Thread starter E. Lee Dickinson
  • Start date
E. Lee Dickinson
Hello, All -
I am curently working on a project (automated scenery, to explain the
crosspost) for which I need a 300 watt motor. I'm looking at a 300w 24v DC
motor, since I am pretty comfortable with DC motor speed and direction
control.
My problem is in coming up with the power source for that. I prefer to buy
a readymade power supply, but everything I'm seeing is either $1000 or "not
for variable loads." I'm not adverse to building a supply, but I know
little beyond the fact that I need a transformer, rectifier, and regulator.
Any suggestions? If the best answer is, "Learn how to control AC motors,"
I'm open to that, but I've been told that AC motors don't reverse well and
don't operate well at low speeds. This project has to change speed and
direction fairly rapidly.
Thanks in advance.
:Lee
Chris Warner
either use an industrial servo drive, or get a 300w 24V transfomer and a
rectifier. The transfer will probably run you about 30 or 40 bucks, teh
rectifier will probably cost you less than 5 bucks.
..02 from
Chris Warner
Torrance Bell
How automated is this scenery? If you need a lot of torque, maybe you
could research an alternative using hydraulics?
I work at UPS stateside, and there are several miles of belts. Some of
them can go in reverse from the flick of a switch. All run off AC and
have some transmission things that turn the rpms into an unbelievable
amount of torque. None of them change speed though. I know some high
pressure fountain (the water kind) displays like the one at the Dorothy
Chandler Pavillion in Los Angeles use some kind of electronic 'thing' to
drop the frequency from 60 hz to something variable between 10-30 hz,
keeping the voltage the same.
Torrance
budgie
Hello, All -
control.
There's a bloke in Adelaide (that's South Australia to you furriners) selling
some brand new Lucent units that would appear to more than meet your needs. He
seems to have a steady availability so might be worth contacting him.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=296&item=5702486892
John Crighton
Hello, All -
control.
Thanks in advance.
:Lee
Hello Lee,
I am a cheapskate, so I would be scrounging a couple of
car batteries that can no longer start a car engine but
still have some life left in them. You can get them for free.
Battery chargers. You can find them everywhere. Bludge one
from your mates/aquaintances. Float charge your batteries.
On the night when the batteries are used often, stick the
charger on boost.
Here is a forward reverse stop motor controller already made up.
http://www.tecel.com/d200/
http://www.tecel.com/d100/
Price looks to be very fair.
Speed control circuit, here is one that you could adapt to the
the above motor controller since it has to be PWM under I KHz.
http://www.solorb.com/elect/solarcirc/pwm1/
That one operates at 400 Hz.
You don't need the power Fet.
Reduce the PWM output signal to 5 volt maximum
to suit the d200 input.
You don't have to use the tecel H bridge.
Just reverse the motor using a heavy duty switch, or
better still, a heavy duty relay. (automotive from wreckers).
Use the speed controller as it is shown.
Some food for thought. Sounds like an intersting project.
Have fun.
Regards,
John Crighton
Sydney
John Nagle
These Vicor power supplies will work just fine with
variable loads. But expect to pay about a dollar a watt.
http://www.vicr.com/products/dc-dc/power_supplies/vipac/
We use these in our DARPA Grand Challenge vehicle.
But really, you're better off finding an industrial
motor controller that runs from 110VAC or 220VAC.
Incidentally, it's worth noting that "brushless DC"
motors and "AC synchronous motors" are the same thing.
Large servomotors (above 1HP) are usually referred to
as "AC synchronous", while small motors are referred to
as "brushless DC". So if you're having trouble finding
larger servomotors and controllers, that may be the problem.
Synchronous AC servomotors are available all the way up
to locomotive size.
The phrase to search for is "industrial drives".
John Nagle
Team Overbot
DuncanWood
Hello, All -
DC
control.
buy
"not
regulator.
and
Thanks in advance.
:Lee
The phrase "as well" is more like it, AC motor controllers have improved
dramatically in the last 15 years. & just build a slightly oversized PSU &
you shouldn't need a regulator for most DC controllers.
James Lerch
.02 from
Chris Warner
Perhaps an ill formed idea, but how about buying a hefty 12vdc battery
charger (say 50 AMP model). Modify to accept 220vac input and 24vdc
output.
I just picked up an el-cheapo 50amp battery charger from Wal-Mart, and
modified similarly. Seems to work just fine..
Take Care,
James Lerch
http://lerch.no-ip.com/atm (My telescope construction, Testing, and Coating site)
Press on: nothing in the world can take the place of perseverance.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
Calvin Coolidge
Dan Mills
E. Lee Dickinson said:
Hello, All -
DC motor, since I am pretty comfortable with DC motor speed and direction
control.
buy a readymade power supply, but everything I'm seeing is either $1000 or
"not
regulator.
Mainline surplus in the UK have 400W 28V switchers for 30 quid each and they
are NICE! I used a few to build a battery charger for a boat.
http://www.mainlinegroup.co.uk/mless/main.php?act=Card&id_element=37
Should do what you need.
Regards, Dan.
Terry Given
field-orientated control essentially decomposes an AC motor into an
"equivalent" separately excited DC machine, thereby decoupling flux and
torque. This allows AC motors to have dynamic response pretty much as good
as DC motors.
With a large enough field-oriented AC drive it is quite possible to demand
such an abrupt reversal that load inertia can twist the shaft right off the
AC motor!
But forget trying to roll your own - you will spend more money on dead
transistors than a whole working drive will cost. And thats before you make
your software work properly.
Cheers
Terry
Daniel Rudy
And somewhere around the time of 05/31/2004 19:16, the world stopped and
listened as E. Lee Dickinson contributed the following to humanity:
Hello, All -
control.
Thanks in advance.
:Lee
300W / 24V = 12.5 amps.
You could get away with a 24v 20AMP transformer (Extra capacity for the
surge current to start the motor, which could also be handled by large
filter caps). You can pick up a 50PIV 25A stud mounted bridge rectifier
at Radio Shack for under 5 bucks. You will need to wind your own
inductor and find the caps needed in the filter, but as for the
regulator, a PWM controller using power mosfets in a h-bridge will work
just fine. You can even use digitial logic to drive the fets if you
want as they approach the ideal transistor.
I have seen fets that are able to handle 80+AMPS of current at various
voltages, case limitation, not die limitation! They are immune to
thermal runaway, and have good tolerance for surges, transiants, spikes,
etc. which is good for a motor controller environment.
Terry Given
"Daniel Rudy"
Daniel Rudy
Semikron make some monster FETs - I just designed a pair of SK115MAA10 dual
95A 100V FETs into a product (all 4 FETs in parallel :). They work well
precisely because of their careful thermal engineering. ordinary packages
are crap for real power.
btw *ALL* fets suffer from thermal runaway (even though books tell you they
dont :). This is because Rdson = f(temperature) - as T increases, Rdson
increases (often its almost proportional). FETs usually operate with
constant(ish) current - ie Rdson doesnt set Ifet. In which case as it heats
up, Rdson increases, so Pfet increases, so Tj increases.....voila, positive
feedback. If your overall junction to ambient thermal resistance is
sufficiently high (Rja_crit), thermal runaway occurs and the FET fries -
this is sometimes the case. OTOH if Rja is much below Rja_crit, the effect
is negligible - this is hardly ever the case. If Rja is somewhere in-between
these two extremes (as it usually is :) then Tj is going to be noticeably
higher than you might expect, and moderate changes in Rja can produce quite
large changes in Tj
Cheers
Terry
W
Winfield Hill
Terry Given wrote...
dual 95A 100V FETs into a product (all 4 FETs in parallel :). They work
well precisely because of their careful thermal engineering. ordinary
packages are crap for real power.
Their 0.7K/W spec isn't very impressive, even tho it is insulated.
- Win
(email: use hill_at_rowland-dot-org for now)
Chris Warner
I have personally see Insulated Gate BiPolar Transistorst that would do 200+
amps.... A simple microchip PIC microcontoller, would cost ya about 5-10
bucks, you can find the circuit to roll your own programmer. But here if we
have a transformer, and a recitifer bridge why not use a dimmer? Better
yet, could hard limit a dimmer at 24v AC, or just a little bit more, then
you can do everything you want with it.
Just a thought, Chris.
Tam/WB2TT
"Daniel Rudy"
You didn't tell him how much the transformer costs. The last time I looked,
a new one was $149.
Tam
Terry Given
- Win
Its not too bad though. The large surface are is helpful, as is the low
internal inductance. Isolation is a huge issue - if required(it usually is),
it inevitably increases the overall thermal resistance dramatically. Semitop
3 packages have a thermal resistance of 0.45K/W. CF a large IGBT module
having 0.22K/W.
device mounting is a major issue at high power. no way would I design a high
power converter with discrete switches!
Cheers
Terry
Rich Grise
Tam/WB2TT said:
"Daniel Rudy" to
buy
I saw a 24V 15A switcher at Fry's the other day for about 30 or 50 bucks.
What's 24 X 15? lessee, 24 * 10 = 240, + ((1/2) * 24 * 10) = 252 watts,
but I didn't really look at the next size up - I think they went up into
the hundred-dollar range.
Good Luck!
Rich
Dan Mills
Ya might want to check the math on that, I make it 360W....
Regards, Dan.
Chuck McManis
And the lack of an Rth(j-a) value makes it impossible to guess what they
would do without a sink, but I guess they assume you will always use a heat
sink on them.
--Chuck
