24v to 12v converter
bertus
3,877
The given page does not give the input voltage range.
We can not say if it works with an input voltage of 18 Volts.
Bertus
Martaine2005
May 12, 2015
5,318
It’s obviously for vehicle use so will have a wide(ish) input range. It will probably work with 18V but not to its full potential.
ivak245
Jun 11, 2021
144
Just try it out. Most of the inverters I have used just won't start up under a certain input voltage, some will beep at you.
kellys_eye
Jun 25, 2010
6,512
Do you know if it's a linear or switched-mode type? Most SM versions will work down to (practically) the output voltage.
AnalogKid
Jun 10, 2015
3,058
Agree. There are a lot of fins, but not enough for a linear regulator.
But wait - that statement assumes western science design values. If we assume a cheaper-than-dirt ethic, it *is* a linear regulator, and assumes direct exposure to a 40 mph air stream.
ak
