24VDC LED on 24VAC power source. Amateur questions.
DavidAlan1062
Sep 22, 2022
7
What is the simplest circuit I can use to hook up a 24VDC 3 watt LED ribbon to a 24VAC 20VA power source? I used a 3K resister to dim the LED and stop the flicker is this sufficient? Will it shorten the life of the LED? Or do I need a bridge rectifier or something? And how should it be wired?
Thank you.
Martaine2005
May 12, 2015
5,315
You certainly can use a bridge rectifier. But maybe a single diode will also suffice.
Wire in series with one of the AC wires. Or a bridge will have AC and DC written on it. Usually the inner two are AC and outer two DC with + and - labelled.
Martin
bertus
3,868
As @Martaine2005 said, a bridge rectifier would do the trick.
You have the flat ones and box ones.
These are common pinouts for them:
Bertus
  • GBU60X.pdf
  • kbpc50 series.pdf
DavidAlan1062
Sep 22, 2022
7
Thank you so much for your help.
To dim the brightness of the LED should I put the resistor on the - side of the led or + side?
bertus
3,868
In a series circuit the order of parts does not matter.
The resistor can be used on both sides.
Bertus
DavidAlan1062
Sep 22, 2022
7
Can you recommend a resister for this purpose so I get the right one? And what are the different values I go by to dim it more or less?
Thank you,
bertus
3,868
Do you have a datasheet of the used led?
That way we can see what is needed.
Bertus
bertus
3,868
When you take 0.4 meter if the strip it will take 11.52 X 0.4 = 4.6 watts.
The max current will be 4.6 Watts / 24 Volts = 0.192 A
As the strip seems to have current limiting build in, you could reduce the voltage by putting some diodes in series in stead of a resistor.
Bertus
DavidAlan1062
Sep 22, 2022
7
Thank you for that. But I don't know about diodes. Sorry I don't know much at all about electronics.
Do you have a name and part number?
David
bertus
3,868
Diodes of the type 1N4001 to 1N4007 will do the trick.
Those can handle currents upto 1 Amp.
Bertus
  • 1N400X.pdf
Sunnysky
Jul 15, 2016
577
What do you want to compromise with simplicity? max brightness, flicker? fully dimmable. Because you must learn how to follow directions and get a few more parts than diodes, capacitor and a pot will burnout as a dimmer with 200 mA.
