W
Winfield Hill
- Jan 1, 1970
- 0
Fred Bloggs wrote...
I wasn't paying attention. The purpose of the circuit was to act as
an input ripple and noise filter?
Walter said:Fred Bloggs wrote ...
With that much dropout it makes no sense to let it drop out. You can keep
the LM317 in regulation by regulating to filtered Vin - 3V up to a clamped
upper limit as required. We are talking about a simple level shift and
diode clamp- and not a lot of excess current. The extra 0.5V drop is more
than paid for by the high performance of the regulator, and you have all
the protection the LM317 offers. Don't forget to add all the usual diode
protection around the IC.
View in a fixed-width font such as Courier.
. Vin>--+-----+--------------|IN OUT|-----+----+-->
. | | | ADJ | | |
. | | +--------+ [220] |
. [4.7K] [10K] | | |
. | | | | 1N4748 | |
. +----------------+-----| Q2 // \ |
. 100U +--------| Q1 | | |
. | | [620] | | |
That's a nice circuit. Am I right that the function of the diode is to
protect Q2's base-emitter junction from reverse breakdown?
Yes- the NPN current source keeps the base of the PNP at ~Vin-5 while
the zener clamps at 22V, so the PNP BE junction starts to reverse bias
at Vin=27V.I like the idea of having the LM317's protection. But I'm still leaning
toward the discrete approaches, because I don't like having this much
input-output differential in the non-clamped case; it means that the piece
of equipment this is powering won't handle brownouts as well. Probably a
non-issue, but I hate for my stuff to be the weak link. I'll probably go
with one of the discrete circuits instead.
I suppose you could adapt the same approach to an LDO, pre-regulating
say 0.2V-0.5V down up until clamp level,- there are a few that handle
40V IIRC, or use a more common and cheaper one and install a zener
over-voltage bypass. If you clamp at 24V and Vin,max=35 then the LDO
only needs to hold off 11V worst case. The trick is to find one in
something easy to heatsink like a TO-220 , and the 250mA current
requirement is not an issue.
