Ben Jackson
- Jan 1, 1970
- 0
I tracked down the fault in a failed power supply to a failed 2N3055
power transistor. It's conducting from C->B in a gang with 4 other
transistors driven by a TIP31. The net result was that the failure
caused the supply to jump to 22V+, far higher than its typical max
voltage, and with no current limiting. Are there any obvious mods
I should consider while I'm fixing it?
___
TIP31 | ___
LM723 ___ |/ |
[Vout>-|___|-o-----| |
22R | |> o---o---o---o---o
| ___ | | | | | |
'-|___|-o |/ |/ |/ |/ |/ 2N3055
2k2 '-----|---|---|---|---|
0.1R | | | | | | | | | |
5W '-' '-' '-' '-' '-'
o---o---o---o---o---->>>
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
___
TIP31 | ___
LM723 ___ |/ |
| ___ | | | | | |
