35" proscan problems (horizontal lines/turns off/high pitch whine)
  • Thread starter playstationdude
  • Start date
playstationdude
Hi everyone. My friends and I got a 35" Proscan TV for free to
replace a broken Zenith 20" CRT (the picture is green and brigher
parts "bleed" over). I digress...in any case, the Proscan has
problems. When i turn it on, the green LED by the power button lights
up, but there is no image except for a few horizontal lines in the
middle of the screen than bend a little; it looks like |) rotated 90
degrees. After a second or so, the green led turns off and so does
the TV. When its doing this, there is a quiet high pitched whine.
Sometimes it will try to cycle on and off a few times before giving
up. Does anyone have any idea what's wrong? Can we use parts from
the 20" Zenith to fix this? I have soldering experience and basic
electronics repair skills.
Thanks!
Meat Plow
Thanks!
You won't be able to repair it with basic skills.
playstationdude
Thanks for the vote of confidence. Seriously, does anyone have any
ideas what I can try? I have a multimeter and an oscilloscope. Its
going to be recycled if I cant fix it.
Meat Plow
I'm just being realistic. You need more than a scope, a meter and basic
skills.
James Sweet
That's not necessarily true, gotta start somewhere, and CRT displays are
generally not too hard to work on. I don't have any specific advice for this
set, but I'd start by checking all the semiconductors in the horizontal
drive section as well as look for bulging electrolytic capacitors.
James Sweet
skills.
I rarely use anything more than a multimeter, basic troubleshooting skills,
and occasionally a tip from someone here. I've fixed dozens of TVs and
monitors over the years.
Meat Plow
This part is what I had some trouble digesting:
quote: "Does anyone have any idea what's wrong? Can we use parts from
the 20" Zenith to fix this"
end quote
You in all your experience may think that these sets are "not to hard to
work on"
Not the case for the totally clueless.
W
William Sommerwerck
end quote
work on"
The OP might be able to fix the set, but given the problem, as he describes
it, he'll probably need to shotgun a lot of components. And that's not the
way you usually fix things.
Without at least a comprehensive service manual, he's likely to have
trouble.
Leonard Caillouet
You might start by posting the model number and chassis number. If you want
a color by numbers fix you need to be more specific.
Leonard
Mark D. Zacharias
this set, but I'd start by checking all the semiconductors in the
horizontal drive section as well as look for bulging electrolytic
capacitors.
Maybe just resolder the coils in the horizontal drive circuit...
Mark Z.
Meat Plow
Ok, get back with the OP and tell him how to fix it.
playstationdude
Leonard
the model number is PS35182 and the chassis is CTC170MA. Is there any
more information i can give?
Thanks- Hide quoted text -
- Show quoted text -
It is a CTC170 chassis.
Even an experienced technician with the service manual would have a
tough time with that one.
Do a google groups search for the CTC170 chassis and see what comes
up.
Before you toss the set, find out if any repair shops are willing to
pick it up for free.
playstationdude
up.
Did a google search and found this site:
http://wa6ati.com/CTC170-171.html
more specifically:
Proscan PS35682 CTC170 cycling on an off CTC170 chassis. Unit will
cycle on and off three times then finally shut off. Gave tech
instructions relating to the this type of shut down complaint. The 9
volt source was OK. The 3.7 volts that must be on pin 2 of U3101 (CPU)
never rose above .8 volts. These two voltages are critical to the
operation of the D.C. detect circuit. Problem was U1902 audio output
IC on audio board.
Does anyone know where I can get circuit diagrams for the set?
