350w Studio Anfi Full Proje
gevv
Jun 23, 2006
126
Specifications
Output Power 200W into 8 Ohm; 350W into 4 Ohm
Music Power 240W into 8 Ohm; 480W into 4 Ohm
Frequency Response -1dB at 15Hz and 60kHz at 1W
Input Sensitivity 1.75V for 200W into 8 Ohm
Harmonic Distortion Typically .002% at normal listening levels
Signal-to-Noise Ratio -122dB unweighted (22Hz to 22kHz); -125dB
A-weighted, both with respect to 200W into 8 Ohm
Damping Factor <180 at 100Hz; <75 at 10kHz, with respect to 8 Ohm
Protection 5A supply fuses
Stability Unconditional
Add new link and schema
Download
http://320volt.com/category/bjt-mosfet-anfi-devreleri/
audioguru2
Apr 6, 2004
12,026
Hello Gevv,
Please tell us something about your amplifier.
Does it have low distortion?
Is it wideband?
gevv
Jun 23, 2006
126
http://www.siliconchip.com.au/cms/A_100618/article.html
http://www.siliconchip.com.au/cms/attachments/show.html?year=2004&month=February
audioguru2
Apr 6, 2004
12,026
I don't want to pay Silicon Chip magazine to read their article.
Instead, I found a kit of the amp and it produces 200W into 8 ohms or 350W into 4 ohms.
One of the kits supplied subtitute transistors that had a different pin-out and wouldn't fit on the pcb.
zak4000
May 12, 2006
92
Whats a ESP file?? Its in the studio_350w_amp_gevv.rar/studio 350 pcb.zip
I'm gussing its some sort of picture...
zak4000
May 12, 2006
92
I found out what a ESP file is.
For those who don't know what it is, its a picture file that needs to be opened with Abode Illistrator or Coral Draw.
zak4000
May 12, 2006
92
What current rating should the 6.8uF inductor L1 be?
And what V/A should the transformer be?
audioguru2
Apr 6, 2004
12,026
350W into 4 ohms is a peak current of 13.3A. 200W into 8 ohms is a peak current of 7.1A.
If used to play music then it won't be continuously operating at full output. So a transformer rated for half the rated power is fine. 100VA for an 8 ohm speaker or 175VA for a 4 ohm speaker.
audioguru2
Apr 6, 2004
12,026
There are many things to consider when substituting power transistors:
Voltage, current, power dissipation, frequency response, etc.
audioguru2
Apr 6, 2004
12,026
The 350W amplifier project from Silicon Chip magazine was 3 years ago. Did they update it? Where is the link?
gevv
Jun 23, 2006
126
old download  link deat (hemenpaylas)  new upolad rapidshare and easy share.
audioguru2
Apr 6, 2004
12,026
I downloaded the original circuit in June, 2006. Is the new download different?
