3D printer's heat bed fabrication (Gerber files)
TendtronicB
Apr 27, 2019
3D printer’s heat bed fabrication
3.0mm FR4 and Aluminum base with sink hole , open slot processing
3D printer’s Magnetic heat bed
[email protected]Tendtronic printed circuit board
admin2
Administrator
Administrator
Mar 13, 2015
184
Could you provide the design files or Gerber files, otherwise this is not usefull for the members of the community.
admin2
Administrator
Administrator
Mar 13, 2015
184
Thanks for attaching the Gerber. Could you give us more information on the rating (votlage/current) of the heating element as well as why this is needed on 3D printers?
jknightandkarr
Nov 25, 2008
37
I can answer the 2nd question for you, as I have 2 3d printers, both having heated beds. The heated beds are required when printing with some kinds of filament, such as ABS plastics. If the bed is not heated to a certain temp n kept at that temp the print adhision may fail totally or even warp your print(s). So the beds will be needed in some cercomstances. Hope this helps. I think as for the voltage, I think most are 12v DC, atleast mine are.
Joe
