3vdc motor PWM problem
randomname
hi all. i posted awhile back about my time fountain project,
everything is up and running! it works beautifully (for a few seconds,
read on) with my new submersible dc motor pump. if you dont remember
the project, heres the deal:
I need a constant drippage of water. I do this with a 3v dc motor,
which pumps through a tiny valve then out the tube. its PWM with the
following: 555 timer, diodes separate up and down time. 1uf cap - 1KOhm
up, 1KOhm down
The timer is isolated from the circuit with a diode and a 1000uf cap,
so the motor doesn't interfere with the timer. thanks for the help
with this. The timer works perfectly, as with a piezo it gives a
steady tone.
The problem is that the motor will rev up to the correct rpm, which
yields the perfect flow of water. Then, after a few seconds, its RPMs
will drop lower and keep bouncing up and down (i can tell this because
there is an audible difference in the tone from the motor, and the
water flow fluctuates)
Any idea what is causing the motor to not stay at the steady rate?
Thanks a ton!
-sam
randomname
one more piece of information: the power supply is 6 volts.
H
Homer J Simpson
Back pressure? How do you relieve the pressure?
randomname
I don't... I need the pressure so that the flow rate is lessened.
randomname
The problem does seem to be the backpressure... but its strange.
When I first turn it on it will work for a good minute or so, then it
will start going into "struggle mode" for a few seconds, then it will
go back to normal. It will alternate between the two states for awhile
and then it will just settle at "struggle mode".
Struggle mode is when its RPMs lower and it doesn't pump enough (bad).
How can I fix this?
Thanks a lot
-sam
randomname
Update:
even without the valve, the motor still struggles. I dont get it.
John Fields
up, 1KOhm down
steady tone.
Thanks a ton!
randomname
Jamie said:
hmm... sounds like the timer is floating around on its bias and
alternating your duty cycle.. maybe you mite want to clamp the input
with a .1 or so cap for the bias control. its been a while but i
think it mite be #5 pin? could be wrong there.
also you mite want to make sure your motor isn't getting hot and
make sure your timer isn't getting hot.
There is already a .1uf cap from pin 5 to ground... and I don't think
it's a timer issue, because when I hook up a piezo in parralel to the
motor, it gives a steady tone.
Any other ideas?
H
Homer J Simpson
Your motor / pump may not like running at the rpms and pressure you have.
Are you trying to build "The Time Fountain"?
http://cre.ations.net/creation/44
If you deliver less than the needed pressure your system won't work. If you
deliver more the motor / pump won't like it. That's why you need a relief of
some sort - a spring loaded valve or similar.
Jamie
randomname said:
Update:
Tim Auton
Sounds like something is overheating and shutting down. I don't think
the 555 has thermal shutdown, but I bet any voltage regulator you're
using does. A finger should be an adequate instrument to test for
overheating in this instance, provided you bear in mind what you're
about to touch might be at 150 C or so (initially just brush it with
your finger, don't grab it till you know it's not too hot to handle).
Tim
randomname
Yes, that's what I've made.
I do think it's a motor issue, but I don't understand how the motor can
affect the 555 timer. The timer slows its frequency too (I can hear
the change in the piezo hooked up to it).
How do I solve this? Where could I find a suitable valve?
I'm going to experiment with different PWM setups (different duty
cycles, frequencies) tonight to see if the problem persists.
-sam
Rich Grise
It sounds like you've built an oscillator.
The PWM comes up, the motor pumps, and you reach a head of pressure.
At this point, you need to regulate your PWM by, maybe pressure or
flow rate, not just constant-current. The motor fills up the vessel,
the pressure reaches the rated value, and the motor stalls. That
relieves the pressure, and the motor picks up speed again, until the
pressure builds up again and the motor stalls again, and so on.
You could put some kind of air buffer in the pipe, or an actual
pressure sensor and make a servo system.
Good Luck!
Rich
randomname
Well, I changed the 1uF cap on the PWM circuit to a .1uF cap,
effectively decupling the frequency (and learning a new word in the
process).
The result? Success! I've been playing with this thing for hours, its
starting to get old, but was definitely worth all of the work.
The trick is to control the flow from the tube so that it drips at a
certain very specific rate.. any faster and it collapses into a stream.
Any less, and it doesnt drip at a constant rate. Luckily, thanks to
some property of water (surface tension I guess) this "drip zone" is
larger than the fluctations of the pump that would cause it to go into
one of the unstable configurations (too little drip, or a stream). Now
that the motor is running steady, the system is very stable.
Next step is to find out how to increase the liquid's surface tension
so I could increase the drip rate without getting a stream, and form
larger drops.
Thanks again for your help, everyone!
James Thompson
up, 1KOhm down
steady tone.
Thanks a ton!
-sam
I have an idea for you. forget using the pump pressure to control the
dripage. Use your pump to fill a reservoir with an overflow tube, then to
regulate the drip make a pulse controlled valve with a solenoid and a soft
silicone tube where the solenoid is compressing the tube closed, then use
the timer to activate the solenoid to control the fluid thru the tube. After
the initial adjustment of a spring to control the pressure on the tube, the
rest is by the timing of the drip pulses.
randomname
I was thinking about this the other day... another 555 timer would just
control the solenoid.
Do you know where I could find a suitable solenoid? Also, I'm not sure
a water drop will fall out fast enough from gravity alone, and it might
require the resevoir to be pressurized (tons of other complications)
For now, this system works, the motor has been running happily for
about 5 hours. Only problem is getting the drippage to stay in teh
"sweet spot" ... not too fast for stream, not too slow for
inconsistancy.
Right now my "valve" is a jumper twisted around the tube, which might
not provide the most consistant pressure.
John Fields
inconsistancy.
Once you've got a steady stream of drops going, you can illuminate
them properly by changing the frequency of the strobe to coincide
with the speed of the drops as gravity causes them to fall.
The easiest way to do that is to build an astable with a variable
frequency triggering a monostable with a fixed period. the astable
will allow you to sync up to the falling drops, and the one-shot
will strobe the LEDs and freeze the image of the falling drops.
Would you like a schematic?
James Thompson
John's approach seems most logical with the triggering of the strobe.
Make a constant gravity feed drip like they have on medical IV tubes, then
have a 2 wire drip sensor to detect when a drip leaves the tube and sync the
strobe from that. When a drip is ready to leave the tube it conducts thru
the liquid and the point when it leaves, it will break conduction between
the 2 wire sensor.
JTT
John Fields
the 2 wire sensor.
JTT
That's not my approach at all. I don't use a drop sensor.
What I'm suggesting is an astable with a manual frequency control (a
rheostat) triggering a monostable with a fixed pulse width.
To understand how it would work, assume that drops are leaving the
tube at a rate of 10 per second, that the astable was astabling at
10Hz, and that the monostable was strobing the LEDs for 10ms every
100ms.
What would happen is that as the drops fell a new one would be in
exactly the same place whare the old one was 100ms ago, and when it
was illuminated by the strobe, the impression would be given that
the new drop was the old drop which was suspended in space.
Now, increase the frequency of the astable a little, and the strobe
will flash a little earlier, illuminating the drop a little earlier
than it did the last one, giving the impression that the drop was
climbing. Slow the astable down, and it'll look like the drop was
falling. Not just the one drop though, the entire column of drops
will be illuminated and they'll all move in unison.
randomname
100ms.
John, that's what I've got already. A simply astable will do, with the
"up time" flashing the strobe, and the (adjustable) "downtime"
controlling the frequency of the strobes. No need for a monostable.
The problem is getting a steady drip rate, its damn near impossible as
far as I can tell. It either drips sporadically or turns into a god
damn stream, which really is starting to piss me off.
I think I'm going to need a drop sensor, but I feel like this is going
to take a lot more work, and even if I did make a drop sensor, theres
no way to get the drops to appear as if theyre moving. It would be
easy to get them to freeze (flash strobe whenever a drop leaves), but
constantly increasing the time period in which the strobe delays after
a drop is detected takes a computer of some sort.
I've acheived some amazing results when I manage to get a stable drip,
but right now it's just not happening.
