4 Watt FM Transmitter
Cerium
Aug 10, 2005
18
I am working on putting together this transmiter. I heard Sasi talk about removing the microphone imput for cd player use. How might I go about doing that? Thanks.  ;)
audioguru2
Apr 6, 2004
12,022
Hi Cerium,
That 4W FM transmitter doesn't have pre-emphasis (treble boost) like radio stations have, so its received audio won't have much treble. Its received audio will sound something like an AM radio or like your stereo with its treble control all the way down. :(
You can mix the stereo output of your CD player into mono and reduce its output level with a 47k resistor from each of its two channels to C2 without using the TR4 stage.
You can add pre-emphasis by connecting a 2.2nF capacitor in parallel with each 47k resistor for Europe and Australia. Use 3.3nF for North America. ;D
Cerium
Aug 10, 2005
18
So would this be correct. The resistor and capacitor in the box are the ones you specifyed.
audioguru2
Apr 6, 2004
12,022
Hi Cerium,
You must get rid of TR4 and R2 and the rest of the mic preamp so it doesn't load down your external input.
Don't you want the stereo input to be combined into mono like this?:
Cerium
Aug 10, 2005
18
I was looking for all the parts and the 2n3553 transister is quite hard to get hold of. Could someone please help me find a more current transitstor that will work. Thanks again, Cerium
ohms
Jan 15, 2006
SHALL I REPLACE WITH 2N2219 WITH 2N2219A FOR T1 AND T2?ANYBODY CAN CLARIFY?
Alun
If your CD player has a treble control you could save yourself the bother and turn it up to maximum. ;D
sneaker73
Apr 4, 2006
audioguru said:
Hi Cerium,
Got a mod for the 15W version to do stereo input?
http://electronics-lab.com/projects/rf/014/index.html <-- this 1.
shahzad-h
Mar 27, 2006
42
HI,Cerium
here's the substitute of2N3553
{BFW47,BFS23,BFS22,BLY34,2SC2419,2N3924,}
mettula
May 24, 2005
81
u can make the veronica - it has a preemphasis network and a pll so it is very stable fm exiter, it only needs an rf power amp if there is any volnteer.....;)
veronica_1w_pll_pro_transmitter.rar
  • veronica_1w_pll_pro_transmitter.rar
