4017 Different LED count
bigkim100
Apr 17, 2013
270
Any way to get a 4017 (Driven by a 555) to count down rather than up. can this be switchable from counting up, to counting down LEDS?, or will I have to use something different than a 4017?
Thanks in advance for any help
PETERDECO
Dec 19, 2019
239
I believe the 4017 only counts up and returns to 0. A microcontroller, such as a PIC, can be programmed to do what you want and eliminate the need for a 555 in the process.
bigkim100
Apr 17, 2013
270
I dont know how to do programming for microcontrollers
Is there a way to do it sans Microcontroller
Martaine2005
May 12, 2015
5,318
Not sure I follow this.
You can put the LEDs in any order you like. Also diode steering for more complex control.
Martin
AnalogKid
Jun 10, 2015
3,058
For non-switchable, counting down only, just connect the LEDs differently.
For switchable between up and down, you will need two chips (besides the 555). One is a 4-bit decimal or binary up/down counter. The other chip is either a 4-line to 16-line decoder, or a 3-line to 8-line decoder. Both are standard CMOS CD4000-series parts.
ak
Audioguru
Sep 24, 2016
3,656
Like above, a "Road Runner" circuit uses diodes to steer the outputs of a CD4017 to make a row of LEDs light back and forth.
