4017 Problem
nwaste
Aug 15, 2005
54
i need a counter which have more stages than one 4017 (10 stages). I was thinking is is possible to build "one" counter from two or more 4017 (when first finish counting of 9 stages than 2nd one starts to counting new 9 stages...)
Please hel with some circuit
Alun
Simple, build two 4017 counters, connect the input of the second one to the last output of the first one.
Staigen1
Oct 26, 2003
695
Hi
Alun, if i remember right it is not that simple, some gates was also needed, maybee i'm wrong, please correct me then.
//Staigen
Alun
I don't think so, just connect the last output (9 I think) to the input so another 4017 and it will count every 10 pulses, so you'll have a 0 to 100 counter, is this what you wanted?
MP1
Dec 7, 2003
3,397
No. Alun is correct (except that 2 4017s will not give 100 counts). To get a continuous count, you simply gang up the 4017 counters. The last count is used to start the next 4017 and so on...
MP
Alun
MP is correct, I was wrong about the 100 counts part although you can make a /100 counter it won't have 100 outputs it'd have two 0-9 outputs, one representing 10s and the other units.
nwaste
Aug 15, 2005
54
Ofcourse is not that simple. You know what happend when you connect last stage of 1st one to first stage of 2nd one? First IC gonna count normaly, but the  2nd one will run 10 TIMES SLOWER, cuz the 1st one will only triger 2nd one when 1st one is on the last stage (that's why 10 TIMES). So, Please help me!
Alun
See audioguru's post.
The only thing is two 4017s give you 17 outputs, if you want 20 you'll need to use three and connect the reset to the output 3 of the last counter (remember output 0 isn't used).
index.php
Alun
If you use a 4011 you could save yourself the 555, four diodes and two resistors.
Edit:
Clould you please provide the origional source
ante1
Jan 24, 2004
4,136
Hi Alun,
If you enter “Bill Bowden” in Google you end up with this: http://ourworld.compuserve.com/homepages/Bill_Bowden/homepage.htm
I thought everyone knew this guy? ;D
audioguru2
Apr 6, 2004
12,022
No, A 4011 has NAND gates. You need a 4081 or 74C08 which have AND gates, and you would still need an oscillator.
I've never tried making a Wien-bridge oscillator from an AND gate or non-inverting buffer, it might work since they have lotsa gain. ;D
Alun
Silly me getting my NANDs and ANDs mixed up!
I think an oscilator made with AND gates might latch up due to the high gain, I wonder if a phase shift oscillator is possible using lots of resistors and capacitors. ;D
audioguru2
Apr 6, 2004
12,022
I guess the gain of an AND gate is so high that it would be a nightmare to try to bias the thing to a linear region.
