500W_inveter
MP1
Dec 7, 2003
3,399
I forgot to answer your original question.
You are using the Divider output, which is Pin #1 on the MM5369. It is only used as a 60 hz square wave generator at this point.
MP
ren_ADD
Dec 19, 2005
16
Hi Mp,
From the sine-wave schematic, I just want to ask what is the
Value of the TWO MOSFET? I thuoght that I have read it correctly
but when I print and review it the printout is difficult to read.
Can you also give a circuit or an IC that would replace
the MM5369?
Thank's :) :)
Ren
audioguru2
Apr 6, 2004
12,026
Hi Ren,
The Mosfets operate linearly in that sine-wave inverter. Therefore they get hot. Really hot.
The inverter's efficiency isn't good. 200W in for 100W out.
It doesn't need the frequency accuracy from an old MM5369 to make a crystal oscillator, any square-wave 50Hz or 60Hz oscillator will clock the function generator IC. The function generator IC can even use its own built-in oscillator.
I wonder where you could find its old obsolete function generator IC. I had one about 30 years ago. The new MAX038 will work.
ren_ADD
Dec 19, 2005
16
hi audioguru,
it seems that Rhon is not around because i've sent an email to him
two weeks ago but until now he don't have any reply. :(
Any I want to ask about the 500W inverter. What is a METALIZED FILM CAPACITOR
is it also called the TANTALUM capacitor?
Thank's
Ren :)
audioguru2
Apr 6, 2004
12,026
Hi Ren,
A metallized plastic film capacitor could also be called a mylar capacitor. Over on your side of the pond they are called "green-caps". The 0.1uF/5% capacitor would be marked "104J" if it is a green-cap. I've also seen reddish-brown ones. ;D
ren_ADD
Dec 19, 2005
16
AHhhh!!! ok now i know. It is only a mylar capacitor not any of the specials.
thank you audioguru!
sureshv
Oct 9, 2004
Hi. I had this unusual problem with the inverter when I connected the batteries. Initially at lower loads (50 watts) it worked fine. But when I started connecting additional loads (100 watts) and batteries in parallel, the inverter would work for 15 seconds and then stop functioning. The emitter resistors would get hot indicating a stuck oscillator. Finally, I managed to blow up the IC probably because of an inrush during one of those off cycles. The power transistors were all safe! In hindsight, I feel, the input voltages to the IC needs to be fed through a resistor of a nominal value say 100 ohms - the circuit consumes just about 10 mA. Secondly, a relay in the circuit that cuts of the low side supply to the square wave generator first followed by a delayed cut off the high side supply will reduce the load on the power line switch/ relay. Any one had similar experience?
audioguru2
Apr 6, 2004
12,026
Hi Sure,
Welcome to our forum. ;D
The oscillator in a CD4047 is pretty simple and is guaranteed to work with a supply voltage of 3V to 18V or more (22V for TI). Since yours stopped then later blew-up, I think it was bad from the start.
I agree that adding a 100 ohm resistor to feed its power is a good idea. Adding a 12V zener diode across it would be even better. ;D
sureshv
Oct 9, 2004
My replacement circuit will have a 100 ohms resistor and a 12V zener (500mw). I will report modifications once I finish the project.
kachew
Jul 2, 2006
104
hi there, i am kachew here....hehe....can i ask  about the sine wave inverter circuit? did anyone try on the circuit post by MP? because i now have similar project on inverter too....my output also need be a sine wave output and surge capability 300W can anyone help me in this project coz after i read all the posts also not really understand and i;m weak in electronics theory...plz help me... :'(
thanks
argeelektronik
Jul 8, 2006
3
audioguru2
Apr 6, 2004
12,026
Hello Aregee,
You didn't say a word about the output stage of a sine-wave inverter you attached that works with PWM to be efficient.
Does it work?
How much power?
Which Mosfets?
audioguru2
Apr 6, 2004
12,026
It looks like the LM324 makes a 50Hz square-wave. The TL494 just breaks it up into a higher frequency so its average output voltage is half of 220V.
Isn't the transformer made special to pass the high frequency from the TL494?
Why doesn't it make a PWM sine-wave output?
