I believe the answer is "leakage current" in conjuntion with a capacitive divider (as mentioned above). If your hands are moist, touch the tip of the scope probe with one hand and the scope ground wire between two fingers with the other hand. Squeeze the ground wire harder between your fingers, and watch the waveform... it will change in aplitude and will always be of the same freqency as the local line voltage. Guess what happens if you do this with battery operated scope? When I say "moist hands", I don't mean with water, I mean with perspiration, which, because of salt content, is a better conductor than plain water.
