555 Circuit Help Needed
H
Howard
Hello to all and thanks for reading. I am attempting to build a 555
circuit that will "listen" to audio output from a computer speaker
(hard wired to the speaker) and fire a relay and hold it for 5 seconds
after the music stops.
I put a Bowden 555 circuit together that fires the relay when a push
button is pressed and holds it for a 5 second time period.
I am looking for suggestions on a circuit that will replace the manual
push button, thus allowing the relay to remain energized while music
is playing.
Any help appreciated.
Jim Gregory
is playing.
You will need to modify /lengthen the 'audio' presence after amplifying it
to 'crushing' and rectifying its envelope to a DC level. Then, by a RC time
constant with electrolytics, make sure it ramps up fast and discharges
(decays) slower. This 'stretched' DC level will have to be amplified enough
to hold a relay on for about 5 secs. That's the gist. The 555 timing
function might be superfluous when audio is punchy and continuous.
Jim
LVMarc
is playing.
5 seconds is pushing the slow side and the R values to thelimimts. You
may want to add counter or use a time delay chip more suited to
##seconds, LSI logic makes a fine series of these delay timers...
Marc
