555 easter egg
F
Frank Buss
Dave demonstrated a nice easter egg in the 555. I can reproduce it at a
harmonic frequency. And you can learn a bit about ground loops:
F
Frank Buss
Robert said:
Please 'splain.. dial-up is not conducive for videos.
For slow connections you can use a trick: start the YouTube video, then
press pause and wait until it is loaded, which you can see at the bar at
the bottom of the video. Then it plays without freezing.
If this doesn't work, or if you still have to pay for the kB: Dave Jones
showed that a standard astable circuit with a 555 starts to generate a
PWM modulated signal near 55.5 kHz, if you don't connect the control
voltage pin 5. When demodulated with a lowpass filter, it is a nice and
clean sinus with 55.5 Hz. I showed this for 111 kHz and 111 Hz. It
starts at 104 kHz :)
