N
Nathan L,
- Jan 1, 1970
- 0
I have DSE kit ZA-9178, and quoting from the text:
"The 10k ohm and 5.6k ohm resistors, along with the 0.1uF capacitor at pins
2 and 6, set the output frequency of the 555 to about 6.8kHz, although this
will vary according to the speed setting."
However, 1.44 / ( (R1+R2+R2) * C) gives me 679.2Hz.
The "speed setting" involves a 10k pot across the supply, with the wiper
connected to pin 5 of the 555. How much does that effect the frequency?
Does the center setting (5k) of the pot set the frequency to 6k8Hz?
I'm wanting to use it to control fans, but at the lower speed settings the
PWM becomes audible. I need to keep the output frequency preferably above
20kHz for the lower speed setting.
Supply is 12V (less protection diode).
Cheers in advance for any suggestions.
