555 Timer Push-On, Push-Off but with timer as well
Ben Parker
Sep 21, 2015
3
I have a monostable 555 timer circuit that activates a relay. This is used to turn a pump on for 60 seconds, it also turns turns on the 555 astable circuit to flash the LED on the momentary switch.
At present the momentary switch triggers the timer, however what i would like is to use the same switch to reset the timer if required. Ie if 30 secs through the cycle you want to stop the timer. I cant find the circuit i need, can anyone help?
Reset pin is terminal 4 on your 555 but would require an additional switch.
AnalogKid
Jun 10, 2015
3,058
The circuit in post #3 is a bistable, or toggle flipflop that latches alternatively in the high and low output states. It does not have the one minute timer in post #1.
To modify your original circuit, change the pushbutton switch to a SPDT toggle switch that is center-off and momentary in both directions (or non-momentary if you return it to the off position manually). Toggle one way to start the timer, toggle the other way (connected to the reset input) to reset the timer. The 555 reset input will need a pullup resistor to Vcc.
ak
GPG
Sep 18, 2015
452
I think this will work It represents the first 555. Time between pushes is ~ 4 secs.Not tested or simmed.
Edit All small signal diodes 1N4148. One of them may not be necessary
GPG
Sep 18, 2015
452
Make R2 R3 1MΩ. As they affect the timing R1 may need adjusting.
