[email protected]
- Jan 1, 1970
- 0
what the heck. i have an LM6132BIM. the second opamp's inputs and
output are left floating. the first opamp is used. its output is
connected to pin 2, its inverting input, with 200k. its inverting input
is also connected to ground via 33k. the positive input (pin 3) is
connected to about 3.5V from a bench supply. in series with the 3.5V is
my DMM set to uA. it measures 596uA!! How is this possible? There is no
other current path except the one from the bench supply to the positive
input and the voltage does not exceed the opamps supply rails. The
datasheet says this opamp has a 110nA nominal input bias current. This
is causing havoc in my circuit because a voltage divider connected to
the positive input has its voltage dragged down by the huge bias
current. WHAT THE HECK IS GOING ON
