Tantalum capacitors Vs. Aluminium capacitors for synchronous switching converter input pin.
Roger_tech
Aug 13, 2025
17
I'm using the LM5166 (Fixed 5V) version, the data sheet suggests to use a tantalum or aluminium capacitors for the input capacitor. The data sheet says that the capacitors is selected mainly because of its RMS current rating and Voltage rating. A higher capacitance just helps in case there's a large drop in input power line. I want to know which capacitor(Aluminium or tantalum) is best and whey they're so. Are there any other alternatives to this? Tantalum capacitors are really expensive. Should I just choose a relatively large capacitance capacitance value?
WHONOES
May 20, 2017
1,242
Input capacitors for voltage regulators are there to decouple the device from the inductance of the wiring or pcb track supplying it and should be placed as close as physically possible (immediately adjacent is best). Failing to do so may cause the regulator to oscillate. Note that an output capacitor is usually required to also keep the device stable. In my experience Aluminium Electrolytic capacitors are entirely suitable. Just follow the manufacturers advice for minimum values. You don't have to stick unwaveringly to the minimum values quoted. Larger, not lower, within reason, is generally ok.
danadak
Feb 19, 2021
1,104
General considerations (polymer vs aluminum) :
aluminum versus polymer capacitors smps
6:33 AM
Aluminum polymer and standard aluminum electrolytic capacitors both use etched aluminum foil, but differ primarily in their electrolyte. Aluminum polymers use a solid conductive polymer, while standard electrolytics use a liquid. In Switch Mode Power Supplies (SMPS), polymer capacitors are favored for their low Equivalent Series Resistance (ESR) and high ripple current capability. [1, 2, 3, 4, 5]
Key Performance Differences in SMPS
Feature [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14]Aluminum PolymerStandard Aluminum Electrolytic
ESR (Equivalent Series Resistance)Exceptionally low (typically 5–20 mΩ). Minimizes heat generation and voltage drop.Higher (often 100–300+ mΩ). Causes more self-heating at high frequencies.
Ripple Current HandlingVery high; handles up to \(6\times\) more ripple current than similar electrolytics.Lower; often requires paralleling multiple capacitors to meet SMPS ripple demands.
Capacitance Over TemperatureHighly stable. ESR and capacitance values remain relatively flat across cold temperatures.Capacitance drops and ESR spikes noticeably in sub-zero environments.
Lifespan & ReliabilitySolid polymer cannot dry out. Offers dramatically longer theoretical lifespans (e.g., 200,000 hours at 65°C).Liquid electrolyte slowly evaporates over time, limiting operational life and increasing failure risk.
Voltage RatingsGenerally limited to lower voltages (typically up to 100V).Available in much higher voltage ratings (up to 500V+ for bulk input filters).
CostMore expensive per unit of capacitance.Very inexpensive.
Safety / Failure ModeTends to fail "open" or without volatile leaks due to solid electrolyte.Overheating can cause the liquid to boil, venting gas or resulting in a popped/leaking vent.
Pros and Cons in SMPS Design
Why Choose Aluminum Polymer?
  • Output Filtering: Their ultra-low ESR and superior high-frequency response make them ideal for output filtering in DC-DC converters. Because of their efficiency, you can often use fewer total capacitors to achieve the same ripple performance.
  • Space-saving: Because of their massive ripple current capability and smaller size relative to their performance, they enable more compact and higher power-dense SMPS designs.
  • No Dry-Out: They do not dry up over time, which ensures long-term reliability. [1, 2, 3, 4, 5]
Why Choose Standard Aluminum Electrolytic?
  • High-Voltage Input Stages: In AC-DC SMPS primary sides (such as 230V mains inputs), high-voltage standard electrolytics are required because polymer technology is rarely available at high voltages.
  • Low Cost: For budget-constrained consumer power supplies where extreme performance and ultra-long lifespans are not necessary, standard electrolytics offer the best bulk capacitance per dollar. [1, 2, 3]
The "Hybrid" Alternative
If you are weighing the pros and cons and need a mix of both worlds, consider Aluminum Hybrid Polymer capacitors. Hybrids use a combination of both solid polymer and liquid electrolyte, offering the high reliability and low ESR of polymers, but providing higher voltage ratings and lower leakage currents typical of traditional electrolytics. [1, 2, 3, 4]
jonas123
Apr 13, 2026
6
In my experience, the capacitor's ESR and ripple current rating are usually more important than whether it's tantalum or aluminum. As long as the part meets the regulator's stability and ripple requirements and is placed close to the input pins, either technology can work well.
