5A regulated power supply
vivek_pv
Aug 2, 2006
43
Dears,
I want to make a regulated power supply (9-25V @ 5A)
Please let me know which IC should be used for this.
(Like we how we use LM317 IC)
audioguru2
Apr 6, 2004
12,026
National Semiconductor invented the LM317 adjustable regulator. In their datasheet for it they show how to increase its output current a few different ways.
ante1
Jan 24, 2004
4,138
You could also try paralleling a few LM338 if you like, this way you don’t need as many parts.
MP1
Dec 7, 2003
3,399
You could also use a 7809 with resistors added like on a 317 for adjustment above the 9 volt mark since you do not need voltage lower than 9 VDC.
MP
gogo2520
Aug 14, 2005
495
          I have a lm338, the data sheet says is can handle 5 amps.
                                          gogo
ante1
Jan 24, 2004
4,138
Hi gogo,
Yes it can handle 5A but not over the entire range of 9 to 25Volts.
