5ohm 20watt resistor
shaiqbashir
Jun 4, 2005
251
Hi guys!
well! i want a 5ohm-20watt power resisitor. First of all please tell me that whether this resistor is available , i mean that is this a standard resistor. And im having some problems finding this in the market. So please can anybody tell me some alternatives to this. I have heard from one of my friends that we can make a resistor according to our required resistance and wattage by using a coil wire by using the formula:
R=pL/A
well! by this i can find a required resistance but how to find a coil of the required power. that is 20 watts.
ur early reply shall be highly appreciated./
take carez
Regards,
ante1
Jan 24, 2004
4,138
If you need exactly 5 Ohms (this one is 25 W) and surface mounting is ok here is an alternative: http://www.elfa.se/elfa-bin/setpage.pl?http://www.elfa.se/elfa-bin/dyndok.pl?lang=en&dok=1775.htm
If you can live with 4.7 Ohms (standard value) you have many options.
Hope this is helpful.
MP1
Dec 7, 2003
3,399
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=3031&Row=380100&Site=US
MP
MP1
Dec 7, 2003
3,399
It looks like they do not keep the search criteria in the link for very long at Digikey. Hmmm....I did not know it expired.
It is a Digikey part number HLWB-5.0-ND. It is a 5.0 OHM 5% 20W TUBULAR Wire Wound Resistor @ US$ 3.38 for qty 1.
Here is the datasheet from the manufacuter, Vishay.
http://www.vishay.com/docs/30210/hlwnhlw1.pdf
Hope that is more helpful.
MP
aartak
Oct 13, 2004
21
Simply plug in parallel 10 resistors each 2Wt 50 ohm
spuzzdawg
Nov 6, 2006
Putting the ten 50 ohm resistors in parallel would give you an equivalent resistance of  200 milliohms not 5 ohms
MP1
Dec 7, 2003
3,399
Looks like you forgot to 1/x your sum. I am assuming you used the parallel formula and came up with 1/50+1/50+1/50....etc and came up with a sum of 0.2. Answer is actually 1/x, thus 1/0.2 = 5. Correct answer is 5.
MP
