5v 20mA max output driving a 5v 500mA max circuit.
Daniel Pitts
I have a signal at 0 or 5v. The source of that signal can only handle
20mA of current.
I have another circuit which needs to have the same voltage level with
reference to ground, but it could have up to 500mA going through it.
The actual current is controlled by a current sink, and it may vary over
time.
In other words, when my signal is low, I want no current. When my signal
is high, I want to source as much current as possible for the sink to
take in.
I have some BJTs laying around, both PNP and NPN, both can support the
max Ic I need. From what I figure, I'll need to hook my signal up to
the base, with at a minimum of 215ohms (Vbe = .7v, leaving 4.3v for the
resistor. 4.3v/20ma=215ohms).
Will a circuit like that work? Is there an easier way? I actually have 8
of these signals (although, only one is active at a time), so I was
hoping to avoid adding the 8 resistors and 8 transistors to my project,
though that seems to be the cheapest way.
Any advice is appreciated.
Daniel.
George Herold
20mA of current.
time.
take in.
An emitter follower? That should be fine. The transistor might use
less than the whole 20mA. (depends on the current gain.) Do you care
about speed? (it might take some time to turn off.) I'm a bit
confused about the load. What are you driving?
George H.
Daniel.
petrus bitbyter
Daniel Pitts said:
I have a signal at 0 or 5v. The source of that signal can only handle 20mA
of current.
reference to ground, but it could have up to 500mA going through it. The
actual current is controlled by a current sink, and it may vary over time.
is high, I want to source as much current as possible for the sink to take
in.
I have some BJTs laying around, both PNP and NPN, both can support the max
Ic I need. From what I figure, I'll need to hook my signal up to the
of these signals (although, only one is active at a time), so I was hoping
to avoid adding the 8 resistors and 8 transistors to my project, though
Daniel.
It's not clear to me what the directions of the currents are both for output
and input. Modern digital outputs can often handle 20mA both sink and source
but an input that requires op to 500mA sink or source? Is it a digital
input? What are the voltage limits of that input? Crucial things to know for
providing a usefull answer.
petrus bitbyter
Daniel Pitts
That's more than fine, 20mA is the maximum the signal source can handle,
but it could be pico-amps for all I care.
Do you care
I care a little about the speed. are we talking more than 10's of
milliseconds?
I'm a bit
The load is several parallel LEDs, all controlled by another chip (a
shift register with latch constant-current sink). Each "led" will get
20mA, and I can have up to 24 on at the same time, (that is, between 0
and 24), so a maximum of 480mA (rounded up to 500ma)
I've posted about this project in the past, its basically my own LED
display, based on an RGB LED matrix.
<http://www.seeedstudio.com/depot/datasheet/2088RGBMatrix.pdf>
I need to switch on exactly one of the rows, and set up the column shift
registers. I switch rows at about 8KHz, so I suspect most transistors
can handle that no problem.
There might be another alternative. On digikey, I found "PMIC - MOSFET,
Bridge Drivers, Internal/External Switch", which look like they do what
I want as well, with fewer discrete parts. It costs a bit more, and the
interface is "serial" rather than a simple 3-to-8 decoder I currently
have. Overall, I'm not sure which is the better approach. I think
overall I'd use a little less power when using the mosfet chip, which
could be useful if I make this a battery powered device.
What's the difference between internal and external for these "bridge
driver" chips? Also, what's the difference between High-Side and
Low-Side in these chips?
Daniel.
George Herold
Hi Daniel, First I may say something wrong.. and then hopefully those
with more knowledge will correct me.
milliseconds?
No. when you saturate a bjt it takes a microsecond or so to come out
of saturation.
(hmm I'm not real sure about that number... maybe 100's of ns?)
Yup you could use a FET too. You've got I*R losses in the FET where R
is the on resistance. In the BJT you'll have (maybe) 300-500 mV of
Vce drop... that might be an issue if you need all of the 5 volts for
the LEDs.
Well low side is when the switch (transistor) is on the ground side of
the load, (so the load floats above ground) and high side is when the
switch sits between the power supply and load with the load
grounded.
George H.
George Herold
If you can stand having the sense of your signals reversed, then a PNP
with the emitter connected to +5V, a resistor to your 20mA driver, and
the collector connected to your load, is what you want.
Tim, stupid question, why is that better?
George H.
petrus bitbyter
milliseconds?
The load is several parallel LEDs, all controlled by another chip (a shift
register with latch constant-current sink). Each "led" will get 20mA, and
I can have up to 24 on at the same time, (that is, between 0 and 24), so a
registers. I switch rows at about 8KHz, so I suspect most transistors can
Bridge Drivers, Internal/External Switch", which look like they do what I
have. Overall, I'm not sure which is the better approach. I think overall
I'd use a little less power when using the mosfet chip, which could be
driver" chips? Also, what's the difference between High-Side and Low-Side
in these chips?
Daniel.
Usually there are more ways to skin a cat and I drew some of them below.
(View using fixed font like Courier)
| | 56R| | | |
| | +---| BC635 |
270R| | | 220R| | | |
| \ | |/ | \ | | | \ ___ |<
| >--+--| BC635 | >---+ | | >---|___|---| BC369
| / |> | / | | / 270R |\
V V V
- LED - LED - LED
O___ O___ O___
O O O
controlled| | |
current | | |
limiter | | |
(created by AACircuit v1.28 beta 10/06/04 www.tech-chat.de)
The one to the left uses a 270R resistor to limit the current through your
driving circuit below 20mA when its output is low. As we do not know the
voltage on the anodes of the LEDs we cannot calculate what current is
driving the base of the BC635 when the output is high. That current may not
be enough to drive the BC635 into saturation as it has a limited gain. If so
you can look for a transistor that provides more gain (hard to find) or a
Darlington for example a TIP122. Pretty much a canon to swat a mosquito and
its saturation voltage may be to high.
A better solution seems to split up the current limiting resistor as in the
example in the middle. If you still have not enough base current you can
lower the 56R as long as you raise the 220R accordingly.
The example to the left uses a PNP-transistor. Note that this circuit lights
the LEDs whem your driving output is low. You only have to be sure that this
output when in high state is raised to at least 4.4V. If not, you may use a
pullup resistor to that output but that will increase the current to be
sinked through the output so you may have to raise the 270R.
petrus bitbyter
Daniel Pitts
I didn't qualify my statement, did I? Because the transistor will pull
up a lot closer to 5V -- with an emitter follower you have the B-E drop
in series with whatever drop your driving electronics has at the base
current. That not only means less voltage, but higher driver impedance
and hence more variation with current.
I don't care as much about the voltages at the various parts of the
transistor. I'm using a 74HC238 to select the row, though if necessary
I could swap that out for 74HC138 (active low instead of active high).
As I've said elsethread the 20ma is a maximum draw from the signal, not
a desired amount. Less would be better actually.
Datasheet for the 74HC238:
Come to think of it, maybe the OP is better off to use NPN emitter
followers and accept that the emitters will be somewhere between 4 and
4.3V (and look at the data sheet of whatever it is that delivers 20mA!!!).
Here's the current-sink (to actually drive the LEDs):
<http://www.ti.com/lit/ds/symlink/tlc5916.pdf>
BTW, I believe its a "conventional current sink", meaning an electron
source. Why does convention have to be backwards from physics!
So, I would either have a PNP with the emitter on the +5v line, or an
NPN with the collector on the +5. The opposite end would be on the LED
line, and that line may be somewhere between 5v and 0v depending on the
current sink on the other side of the LEDs. The end of the transistor
not tied to +5v would likely be between 2v and 5v. 5v means "all the
LEDs are off anyway", so I would expect no current. 2v means I'm
dropping 3v across the transistor at potentially 500mA. Hmm, 1.5 watts.
I wonder if my components can handle that. Unless (and likely) my
analysis is wrong.
So it's not a stupid question.
I'm glad he asked then ;-)
Daniel Pitts
20mA is asking a lot from the part, and you want to be careful -- IIRC
not everyone specifies that much.
Because the convention was established before people knew the polarity of
the electron. The coin came up tails...
That was a lament, not a question ;-)
If the transistor circuit is operating properly then it should drop 0.2V
or so in the PNP case, and 0.7V or so in the NPN case. It should not
vary by more than 0.2V in either direction, if that.
Right, I realized this after I posted. Indeed, if I'm in saturation, the
voltage drop should be acceptable.
What transistor are you planning on using? Or maybe I should say -- what
candidates do you have in le box de junque?
I have plenty of SS8550DBU (PNP) and PN2222ATA (NPN). I was also
looking at some FETs on digikey last night.
I'm not opposed to ordering other parts. I know what I'm making isn't
novel, but if I can "do it cheaper", I might consider trying to sell my
end-product. In any case, I'm enjoying the learning experience.
petrus bitbyter
I have plenty of SS8550DBU (PNP) and PN2222ATA (NPN). I was also looking
You'll have to drive a PN2222A next to its limits and that's never a good
idea. If you want to give it a try, look at the datasheets of the
manufacturers. They have different specs for the same type of transistors.
That SS8550 suits better. A 15-18mA base current should be enough to turn
the transistor on. If the transistor is not driven into saturation, it may
become (too) hot. You have to account for that.
petrus bitbyter
Daniel Pitts
I don't think you could trust a PN2222(whatever) to 500mA. You could use
one or two per LED with the base leads common, but that uses up a lot of
space.
Here's the datasheet from my supplier:
<http://www.fairchildsemi.com/ds/PN/PN2222A.pdf>. 500ma is %5 above my
"worst case" (a pure white display) Looking at the datasheet though, the
current gain is 40 there, meaning I'd need at least 12.5ma to the base
to drive the thing to saturation. I could do that, but as you said that is
Again, a P-channel logic-level MOSFET would be ideal for this. If you're
ordering from DigiKey anyway I think you'll find tons of candidate parts,
probably for pennies each.
I was hoping for that, though I'm not seeing it. I'm seeing plenty of
N-channel mosfets for < $0.30 (although none that cheap can handle the
amperage I'm expecting), but the cheapest P-Channel is $0.42. That
would add $3.20 to my project.
I was also considering a Darlington, but that seems to be as expensive
as a similarly suitable P-channel MOSFET. It would be cheaper to hook up
two transistors myself.
<http://www.onsemi.com/pub/Collateral/2N6040-D.PDF> could be suitable. A
bit overkill (8A, 75W), but only $0.30 each. Comes in both PNP and NPN
flavors.
Actually, there is an octal array that might also be worthwhile...
<http://www.st.com/web/en/resource/technical/document/datasheet/CD00000179.pdf>
Still only 500ma max, but again, that is my worst-case scenario. This
array is only $0.27. It also says outputs could be parallel to increase
max current, so I could in theory add two to my project to support up to
one amp, and it would only add a half dollar to the cost.
The Toshiba PNP version:
<http://www.semicon.toshiba.co.jp/docs/datasheet/en/LinearIC/TD62783AFG_en_datasheet_091116.pdf>
Seems like one of these might be the way to go. Have an array of 8
simplifies a lot for me too, though it does add one big chip to the
project ;-)
Thanks again for all the advice.
Daniel Pitts
If 500mA is only 5% of the maximum then you may be OK, because if I
understand what you're doing correctly, the transistor will only be on
for 1/8 of the time. That means that -- to the extent that the rating is
for thermal considerations -- you can push things.
Yeah, I remember considering that at some point, but then it slipped my
mind again. Too much going on in my life outside of this hobby ;-)
So basically, if I have 480mA through one device with a duty-cycle of
12.5%, then as long as it can handle the "peak" without damage, the
average is about 60ma. That greatly improves my wattage as well. I
could also consider lowering my current by a little over a 3rd, and just
use the original IC I have now. This might be feasible since current
relates to LED brightness, and they may be bright enough at 6mA.
Especially for an indoor portable display, which was my original intent.
Something to ponder.
Current gain will be a problem. Note that they're specifying the current
gain at 500mA and a Vce of 10V, and note how much the current gain drops
from 150mA and 10V vs. 150mA and 1V.
On the NPN Darlington array I linked to, the current gain is 1000. Well
more than enough for my needs. I think this really is the way for me to go.
The Toshiba one I linked to (the TD62783APG) doesn't list current gain,
but the I-in(on) at with VIN = 3.85 V is a max of 260uA. Well below my 20mA.
What about this PMOS: http://www.digikey.com/product-detail/en/
IRLML5103TRPBF/IRLML5103PBFCT-ND/812496. Or are you sticking with
through-hole?
Yeah, pretty much through-hole only. This whole thing is on a
solderless breadboard. I've considered designing a PCB, but that's a
whole other experience. I have soldered SMT stuff before (had a kit I
bought at a workshop). It was interesting, but I don't think I'm ready
to design an actual circuit board from scratch.
Anyway, Thanks again for the feedback and advice. I really appreciate it.
