4-20mA circuit issue
sidexter
Feb 23, 2023
I have a circuit which gives 4-20mA current, however the as the sensor drift the current also drift below 4mA (which is ideally correct ).
however, i want to restrict the current to 4mA , i.e. the current should increase from 4mA to 20mA but should not go below 4mA incase of drift in sensor.
Request you to kindly assist on how that can be achieved.
Thanks & Regards,
Siddhesh
14,317
Show us a schematic diagram of your circuit. Without it we have no chance of giving you a meaningful answer.
kellys_eye
Jun 25, 2010
6,512
The principle of the 4-20mA is that when your sensor outputs 0 the circuit 'sends' 4mA....... if it's dropping below 4mA then there's something fundamentally wrong.
sidexter
Feb 23, 2023
Thank you for the prompt reply, the scaling is working fine, infact there is no issue with the circuit.
my issue is, I dont want the current to fall below 4mA.
according to the circuit, i get 4mA when TP4 is at 0mV, but when sensor drifts, TP4 goes into negative voltage usually -20mV to 60mV. i want to restrict the TP4 voltage to 0mV in this case.
Siddhesh
14,317
Klick on it, rotate by 90 °.
@sidexter : what part is U2? Wouldn't this part offer a setting that ignored negative inputs?
kellys_eye
Jun 25, 2010
6,512
So what? The fact that:
Which means it's working as it should.
What relevance has the inner workings of the 4-20mA circuit to do with what you want to read? If you are getting 4mA when the (external) sensor reads 0 and 20mA when the sensor is reading (whatever) maximum then the system is working as it should be.
Or am I missing something here?
