60 in Hitachi big screen problem
My Hitachi 60 inch screen is about 7 years old. I suddenly lost
color and the picture is very fuzzy.
Any suggestions? My 5 year extended warramty has run out and it's
the
middle of football season !!!
ps, can I turn off NFL sunday ticket and get a refund?
James Sweet
the
Best suggestion I can give you is to have an experienced tech come look at
it, if you don't know your way around the inside of a TV set and have some
basic test equipment then there's zero chance you'll be able to fix the
thing yourself.
Leonard Caillouet
Post the model number, more detailed explanation of the symptoms and the
conditions under which they occur, and you capability in terms of
troubleshooting and repair. You will likely get more appropriate advice.
Otherwise, call an experienced tech.
First thought might be a comb filter problem. Leaky surface mount
electrolytics are common in some models, but then it could be a bad cable or
any number of other problems with your vague info.
Leonard
David
Need more input.
Honestly, you need to call out an experienced technician with the
Hitachi sets to have a look at it and provide you with an estimate.
The trip charge to the door should be around $60-$100 for an in home
estimate.
David
