7 Segment display pin connection
ananya
Sep 28, 2010
3
I got this circuit 3 phase pump water level controller from EFY website.
I tried circuit connections in PCB and its working, fine.
Since the pin connections from driver IC's to 7 segment LED display is not clear, as circled in red color in attached file. I did't connect the display.
Please help me and give the pin connections from driver IC to 7 segment display.
Actually they've gone one better than providing you the pin numbers, they tell you the segments. That allows you to easily use any 7 seg display.
The letters a through g refer to the segments. If you get a datasheet on the display it will tell you which pin corresponds to which segment.
Wikipedia will tell you about the segments.
If you can't find a datasheet then you can use a multimeter on a low ohms range to figure out the pinout.
ananya
Sep 28, 2010
3
In this circuit diagram pin connections of 7 segment display mentioned a,b,c,d,e,f,g are not clear to me, I need those notations clearly.
ananya
Sep 28, 2010
3
Yes, I do know in general the 7 segment LED pin numbers (or alphabets)
The problem is in the circuit diagram given in the EFY website
http://www.electronicsforu.com/efylinux/circuit/Cir29.gif
So that it will be helpful.
Thank you,
Arun Nehru
14,487
Thank you,
Arun Nehru
Steve has told you how to work out the pin identifications :)
