7 Segment Display Using Xilinx XC95108 CPLD Board
Im working on a lil project and i need some help with it so if you
have any ideas im open to all of them. I greatly appreciate it.
As shown in the class, a CPLD board used in our laboratory has been
used to display a counter output. This project is asking you to use
your knowledge in the ELEN 327 course and the experience you
accumulated in ELEN 328 to design a circuit, which is able to drive
the display on the Xilinx XC95108 CPLD board and show the exact
demonstration.
Things that concerned:
1. Design a counter that counts the cycle of even decimal numbers
only, starting from 0, 2, 4, ... to 20 and restarts from 0 again. You
can use any kind of flip-flop circuits, such as D-type, T-type, or JK
flip-flop.
2. Design a decoder, which decodes the output of a binary counter, and
translate it into a seven segment driver. Since the counter starts
from 0, ends at 20 and starts from 0 again, you need two 7-segment
display to show it. The actual pin connection information about these
two 7-segment display is at the end of your laboratory book.
3. Clock divider, which uses the high-speed crystal oscillator as the
source. The frequency of the crystal oscillator on our CPLD board is
4 MHz. You need to reduce this frequency in order for our eyes to
identify the counter output. You can also call this clock divider as
a speed controller. If you adjust the speed right, this display can
be a normal wall clock.
The block diagram of this design is shown below:
Crystal Oscillator ------->Clock Divider--------->Even Counter---------
linnix
lil - Laughing Inexplicably Loud?
When I was in College LLT ago, I did projects for girl friends. Try
looking for smarter friends in your class.
Donald
What school is this ??
demonstration.
Oh, wait I found it:
http://www.eng.ncat.edu/dept/ecen/
Maybe one of these people can help you:
Sharlene Coleman Graduate Program Assistant McNair 549
David Eubanks Lab Technician Cherry 216A
Janice Fisher NASA Ace Program Assistant McNair 547
Anita Huff Graduate Program Manager McNair 318
Lenora Kirby Administrative Assistant McNair 549
Audrey Ling Retention Coordinator McNair 545
Ali Osaraeh Cherry 306D
Trevor Taylor Undergraduate Program Assistant McNair 551
flip-flop.
Good Luck, your going to need it.
donald
