741 circuit amp wont turn on
Status
Not open for further replies.
Jeorge
Oct 31, 2016
I have built a small amp circuit with a light in the circuit. But the light wont turn on and no power is going through the board. I have used different types of rechargeable and normal non rechargeable 9v batteries, but still no power. My amp circuit is made up of a resistor, capacitor and 741 op amp.
Any help and advice would be appreciated.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Post a schematic. Draw it on paper if you have to and take a picture.
Jeorge
Oct 31, 2016
Heres my drawn schematic.....Hope it makes sense.
14,486
as drawn, no it wont work
you have a capacitor in line with the input, why? is there a DC or AC voltage going in there ?
you have a capacitor in line with the lamp, again, why ? do you know DC doesn't go through a capacitor ?
you have the lamp going back to the non inverting input ( the + input), this is incorrect the + input, the lamp should be going to 0V
when pin 4 of the op-amp is going to
ohhh and you have pin 4 marked as 9V instead of 0V
Herschel Peeler
Feb 21, 2016
401
What does it take to light the lamp? Voltage? Current?
The LM741 can't put out much current. And the more current you draw the lower the output voltage.
What voltage in?
Try it without the capacitors.
No, this will never work, even without the capacitors. The input pins cannot source or sink current, and that is what your circuit is expecting.
How about telling us what you are trying to do. I cannot determine that from the totally flawed schematic that you posted.
Audioguru
Sep 24, 2016
3,656
I suspect that he wants the light bulb to light up when there is a low level AC signal at the input. Then a properly biased amplifying opamp van drive a rectifier/filter circuit that drives the light bulb.
The datasheet for a 48 years old 741 opamp says that its non-inverting input pin3 will not work if it is within a few volts from ground but here it is at ground.
The incandescent light bulb has no voltage or current rating. If its part number was shown then we could look them up.
14,486
Thread is closed
till the OP responds to me
@Jeorge
please PM me if you understood what was commented on and you have further info to add
and I can reopen the thread
Status
