Hello guys, I'm using the UA741 op-amp but theres a problem.. offset voltage ! I always get (saturated +ve output) until the inverting input (V-) is 1.8 volts greater than V+.
Now 1.8V... isn't that ALOT ?
Anyway, I tried using the offset null pins but they didn't work !
Here's what I did exactly:
Pin 2 (V-) : GND
Pin 3 (V+) : GND
Pin 6 (Vo) : DMM
Pin 1 (offset null) : 10k Pot beginning
Pin 5 (offset null) : 10k Pot end
Pot slider ---> GND
Supply pins: +13v & GND.
the opamp insists on giving +13V (sat.) regardless of the pot. setting.
Does this mean a bad IC ?? I've tried 3 of them so far.. maybe the whole lot was bad ??
Pin 2 (V-) : GND
Pin 3 (V+) : GND
Pin 6 (Vo) : DMM
Pot slider ---> GND
