74HC(T)245 quiescent current
O
OldGit
Hello
This is from the datasheet, and I don't really understand it:
"Icc quiescent supply current 80uA.
deltaIcc additional quiescent supply current per input pin Vi=Vcc - 2.1V,
other inputs at Vcc or GND. Vcc=4.5 to 5.5V
An or Bn inputs 180uA
OE input 675uA
DIR input 405uA"
I get the bit about Icc at 80uA, and I get the bit (not quoted) about
dynamic power. But what's the additional Icc per input pin about? And why is
it at Vcc - 2.1V?
Sorry if it's a dumbo question.
Ta for any hints.
O
OldGit
Jan Panteltje said:
Have not read that datasheet, but likely when halfway 'on'
both of some MOSFETS (pull up + pull down) are partly on, so then it draws
some power.
I thought that might be the case (honest ;) but only just before I read your
post. Thanks.
So I need to calculate the amount of time the inputs spend in this halfway
point. Should be easy enough.
O
OldGit
I know, my PC clock is wrong. Corrected now (I hope).
Jim
both of some MOSFETS (pull up + pull down) are partly on, so then it draws some power.
I would think that it's the minimum high level input voltage that you
might expect when interfacing to TTL (and the resultant current due to
the voltage being 'halfway on', as noted above).
Joerg
Jan is right about "half way on". The input inverter (even that of a
Schmitt trigger such as the 74HC14) will conduct substantial quiescent
current when the input pin resides in the middle. The middle is defined
by the IC designers, for HC logic it is truly in the middle, meaning at
VCC/2.
Jim Thompson
VCC/2.
The spec for "middle" is actually 30%-70% :-(
In my custom designs I often make such input devices either quite long
or use current sources and sinks to limit "overlap" current.
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona 85048 Skype: Contacts Only | |
| Voice:(480)460-2350 Fax: Available upon request | Brass Rat |
| E-mail Icon at http://www.analog-innovations.com | 1962 |
I love to cook with wine Sometimes I even put it in the food
Joerg
Yeah, you's guys are always +/-8dB while us guys limit ourselves to
+/-3dB :)
When it comes to very speedy devices the chip designer is probably
between a rock and a hard spot.
Jim Thompson
+/-3dB :)
Wouldn't "speedy" imply very little time spent in the overlap region?
Only slow stuff, or stuff that can float around, requires such
limiting.
...Jim Thompson
Joerg
limiting.
Sure, but when the input signal isn't always under your control the
overlap region remains a concern. I get that question over and over
again: "Why is this draining the battery so fast" ... measure, measure,
measure ... "Well, those two inputs are not anywhere close to logic
levels" ... "But it's a Schmitt" ... "Doesn't matter, the input inverter
still seeps" ... "Oh".
Jim Thompson
You need to learn to speak harshly to your customers when they're
doing dumb-ass things ;-)
Of course, in my case, I can contrive my own frontend to prevent/solve
such issues.
...Jim Thompson
Joerg
Nope, old rule: Always be mild-mannered and never point fingers,
consultants aren't supposed to run around with smirky faces :)
such issues.
Lucky you. I sometimes have to interface with stuff where I get sick
when I see it the first time.
Jim Thompson
Of course. But there _can_be_ off-the-shelf fixes. Ask me the next
time you run into such a situation (free home demonstration ;-)
...Jim Thompson
Joerg
[Iq of first inverter stage]
Is the tool du jour to fix it a Beretta or a Glock?
Jim Thompson
No! No! Try me. I can likely suggest off-the-shelf components for
such situations ;-)
...Jim Thompson
K
krw
No, you speak softly and carry a big bill.
such issues.
But, "speedy" and long devices (and other protection means) don't tend
to go together. C == bad
Jim Thompson
All my "floaty" inputs are slow.
...Jim Thompson
K
krw
Because you do that simple analog crap, you can afford to be slow [*].
[*] Now that I'm retired, I can too.
Jim Thompson
Speak for yourself. As recently as two years ago I was doing stuff at
5.5GHz ;-)
A present project includes a 500MHz VCO.
...Jim Thompson
K
krw
On Tue, 14 Jul 2009 15:45:12 -0700, Jim Thompson
Jim Thompson wrote:
Jim Thompson wrote:
Jim wrote:
On a sunny day (Tue, 14 Jul 2009 13:10:57 +0100) it happened "OldGit"
Hello
OE input 675uA
DIR input 405uA"
it at Vcc - 2.1V?
Ta for any hints.
VCC/2.
+/-3dB :)
limiting.
such issues.
5.5GHz ;-)
I did. You didn't do that with long channel FETs or current limiting
input devices.
Same.
