74HC14 issues please HELP!
sawula
Nov 26, 2010
I have two built circuits and I am trying to integrate them. In one ciruit there is 74HC14 IC and there is a 2.2k resister between two gates (pin2 and pin 3) and in other circuit they are directly connected (pin1 and 2). I want to know why is 2.2k resister used? I know the purpose is to invert the output of first gate but why we can't directly connect those pins in both cases?
Directly connecting the output of a Schmitt trigger to it's input will cause it to oscillate at a very high frequency. With the addition of a resistor you can then add a capacitor between the input and ground to control the frequency.
Check page 5 of this.
This talks about CMOS oscillators in general and how a ring of inverters will oscillate.
edit: Naturally, without the rest of the circuit it is impossible to tell if something else is going on.
Frankly, I think the short across pins 2 and 3 would be an error.
sawula
Nov 26, 2010
Sorry for the mistake. I wanted to say pin2 and pin3. The two circuits are x10 transmitter and a x10 receiver. 74HC14 is used to detect the zero crossings of the AC power lines. (x10 is a protocol that is used to communicate over power lines) And I want to combine both transmitter and the receiver together and create a transceicver. In the transmitter ciruit pin2 and pin3 of 74HC14 is directly connected and in the receiver circuit they are connected through a 2.2k resister. I want know the difference inbetween so that I can use either directly connection or the connection through 2.2k resister for my combined transceicver circuit.
As shown on that diagram, the 2k2 resistor does nothing significant.
However, I'd wager that there are power and ground connections (and a resistor) that connect to the 4N35.
Did you arrive at this circuit by tracing connections on a PCB?
