Replacement for 74HC14
MrWho
Dec 16, 2011
9
Could please somone help me can I replace the 74HC14 with any of those:
74HC14-2 CMOS HS HEX SCHMITT TRIGGER N/A
74HC14D-PHIL CMOS HS HEX SCHMITT TRIGGER 14P SMT 57PCS/TUBE .65ES SOGENT Philips Electronics
4HC14D-PHIL3 CMOS HS HEX SCHMITT **SMT T/R Philips Electronics
74HC14N-PHIL1 CMOS HS HEX SCHMITT TRIGGER Philips Electronics
74HC14PW-PHIL CMOS HS HEX SCHMITT TRIG TSSOP14 SMT T/R Philips Electronics
Thank you very much :)
Those are *all* 74HC14's, so any is OK.
You'll find that some are easier to work with than others however. TSSOP is a package that has very closely spaced pins. You probably need to look for a 74HC14 in a DIL (or PDIP) package.
You'll find that the part mumber will typically include "74HC14" with prefixes and/or suffixes. The prefix normally designates the manufacturer, and the suffix things like physical package, and other electrical characteristics.
MrWho
Dec 16, 2011
9
Thank you very much !
