74LS193 Cascading Question
Bart
Hi All,
I've successfully cascaded 4 of the 74LS193 binary up-down counter chips to
count up to full, off a 555 oscillator. Now I'm stuck. I want the circuit to
count to full and then count back down to zero and continue this cycle
endlessly. I've googled my flanges off and can't find a circuit where this
is done. The datasheet brags that this is the advantage of this chip that it
can be cascaded without additional elements so I was sure I'd find where
someone had done this before but I'm googled out.
Any help is greatly appreciated,
Bart
Michael Black
Bart" (bborb@fusedotnet) said:
Hi All,
Bart
"Cascaded" as in hook the output of one into the input of the next, so
the combined counting is increased.
You'd have to add logic to switch the count direction after the full count
and when it gets down to zero.
Michael
Bart
Michael
Yeh, that's where I'm stuck. I've successfully cascaded all four chips to
count up.....I can't figure out what circuitry I need to add. I know how to
make them cascade count down but I have to manually switch wires to make it
happen. I want it to automatically switch count directions when count is
full and when count is zero.
Bart
Bart
Chris
Bart said:
Hi All,
Bart
Hi, Bart. Count up from 0000 to 9999, then reverse direction, counting
down from 9999 to 0000. Rinse and repeat.
Not too difficult. I'd assume you've got all zeroes at the preset, and
are using a power-up pulse to reset the count so you can start at zero.
Now set up an R-S FF with the Set condition being a count of 0000 (all
four TCd active) OR the reset pulse. The Reset condition is the count
of 9999 (all 4 TCu active). The R-S FF outputs can be ANDed with your
clock to route the clock pulse to CPu or CPd.
Here's how it works. Your power up pulse sets the count at zero, and
also sets the R-S FF so the counts will be routed to the Count Up
input. After 9999 clocks, all four Terminal Count up outputs will be
high, and are ANDed to the Reset input of tghe FF. That steers the
next clock pulses to the Count Down input, and so on.
Look at the data sheet for details:
http://www.onsemi.com/pub/Collateral/SN74LS192-D.PDF
Of course, you've now got four LS193s, a flip-flop, and some
combinational logic. You're now at the point where a PIC is more
sensible solution.
Good luck
Chris
R. Steve Walz
Bart said:
Hi All,
Bart
Use this schematic, below, and the '193's UP, DN, CO, and BO to
daisy chain several of the '193's together, CO to UP and BO to DN,
and use the hand-made flip-flops on the opposite ends of the chain
to change the direction just as shown.
Of course if you want it all decoded, the '138 decoder will need
to be expanded, cascaded with multiple layers of decode expanding
like a tree. When you get to wanting that you may just want a
shift=register chain instead.
http://www.armory.com/~rstevew/Public/LED_Ccts/Niterider138.gif
-Steve
Chris
sensible solution.
Good luck
Chris
Something like this (view in fixed font or M$ Notepad):
| To 4 ea. MR
| TCd1 -| | __
| |__ RST-o-\ \
| TCd2 -| \ | |-.
| | )------/__/ |
| TCd3 -|__/ |
| TCd4 -| |
| | __
| TCu1 -| | | | | | )- toCPu
| |__ '-oS Qo-)--|__/
| TCu2 -| \ | | | __
| | )--------------oR Q'o-)--| \
| TCu3 -|__/ | | | | )- toCPd
| | '----' o--|__/
| TCu4 -| |
|COUNT ---------------------------'
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
At count 0000, you have to AND all four of the TCd signals, and the
same with the TCu signals at 9999. The RST is the power-up pulse you
use to set initial count to 0000. Obviously that also sets the
counters to up-counters.
Simple? Unfortunately, I guess you're at 7 ICs, plus whatever you want
to do with the BCD outputs. Acres O' Digital.
Good luck
Chris
Chris
| To 4 ea. MR
| TCd1 -| | __
| |__ RST-o-\ \
| TCd2 -| \ | |-.
| | )------/__/ |
| TCd3 -|__/ |
| TCd4 -| |
| | __
| |__ '-oS Qo-)--|__/
| TCu2 -| \ | | | __
| | '----' o--|__/
| TCu4 -| |
<snip>
Sorry -- the TCu and TCd are low on the last count, and go high as they
roll over up and/or down. So, the two 4-input ANDs should be 4-input
NORs.
Chris
Jamie
Bart
Bart
put a flip flop on the last output pulse when it over flows.
the Q's and !Q directly drive the direction of count..
this way it will simply reverse count when it hits the end.
etc...
petrus bitbyter
Bart said:
Hi All,
to count up to full, off a 555 oscillator. Now I'm stuck. I want the
circuit to count to full and then count back down to zero and continue
this cycle endlessly. I've googled my flanges off and can't find a circuit
where this is done. The datasheet brags that this is the advantage of this
chip that it can be cascaded without additional elements so I was sure I'd
find where someone had done this before but I'm googled out.
Bart
Bart,
That 74LS193 are weird old things. You will have found that they are
cascaded by connecting the carry output to upcount of the next chip and the
borrow to the downcount. So this counters may by internally synchronous, all
the rest is asynchronous. You will draw the same conclusion when you realise
that the driving clock(s) are connected only to the first counter. To
achieve your goal we'll have to open the toolbox of the old asynchronous
designers with the suitable logic and a bunch more or less dirty tricks.
Mentioned by others already is the input circuit to switch up/down and lead
the clock to the desired input. For your and mine convenience I draw it
below.
__
Setup -----| | __
|& |o-+-----| |
+--|__| | |& |o---Cup
| | +--|__|
X |
| __ | |
+---| | | | __
|& |o-+-)--| |
Setdown-----|__| | |& |o----Cdo
+--|__|
clock |
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
One 74LS00 will do the job. Remind that the trigger has active low inputs.
So Setup and Setdown are normally high and you select by pulling the
corresponding input low for a short time. Trying to set both at the same
time will block the counter. You can't count up and down at the same time
anyway.
To find a way to make the counter switch automatically, you'll have to look
at the datasheet of the LS193. If you don't have it find it, download it and
print it out. You can't do any serious work without it. The datasheets
contains pulse diagrams. (At least mine - Texas - does.) You can see that,
when counting up, the Carry appears just half a clockcycle before the
counter rolls over. The first three counters in the row simply feed through
the carry. It's on the trailing (rising) edge of that pulse of the fourth
counter we want to act. That's to say the whole countercircuit should not
roll over but counts down one step and switches to countdown mode. The
latter can be achieved by presenting a short negative pulse to the Setdown.
To count one down at the same time can be achieved by presenting 1111 1111
1111 1110 to the parallel load inputs and a short negative pulse to the Load
input. Now that small negative going pulse can be made by a monostable. Half
a LS221 will do the job. Use the positive edge trigger (B) input to connect
the carry to and the inverted Q output to drive both Setdown and Load. The
pulse length should be shorter then half a clock cycle but long enough to
get the load done. One us (microsecond) will do. You may find glitches on
the counter outputs which can be considered "normal" when you use
asynchronous resets or loads. No need to say you'll need the datasheet of
the 74LS221.
When counting down, the Borrow on the last LS193 appears when the counter
reached all zeroes. We cannot do the load-trick as we have the parallel load
inputs in use already, so we need something else. That else is another
monostable, triggered on the rising edge of the borrow. This time we need
the inverted Q output to trigger the Setup and the Q output to reset the
counter as a whole. The disadvantage is that the all zeroes state resides
twice the normal time, so two clockpulses.
You can overcome this disadvantage at the cost of some extra hardware and
glitches but I consider this story long enough for the moment.
petrus bitbyter
Bart
Bart said:
Hi All,
Bart
Thanks so much for everyone's replies. Whew, I'm getting great info from
you people. I've probably got every electronics book I could find from "Half
Price Books" and also Googled till my eyes were bloodshot but this group has
been critical to my successes on many projects.
I simulated many configurations with cascading the 74LS193 up-down binary
counters and hit on this design that does what I'd hoped.
http://home.fuse.net/consultec/74LS193.jpg
I'll try and breadboard this first chance I get, I don't always trust
simulators.
Bart
Chris
simulators.
Bart
Hi, Bart. A couple of notes on your circuit:
The '193 TCu output goes low when the chip reads a "9" ouput, and the
clock is low. This means your logic will toggle when the most
significant digit gets to "9" when it's counting up. Meaning your
count up to count down transistion will go 898, 899, 900, 899, 898, &c.
Also, since you're not using TCd on the last chip, it won't toggle
until the digit gets to 9, which means an extra count, AFAICT. The
count down to count up transistion will go 001, 000, 999, 000, 001, &c.
So if you're going up to 999 instead of just 900, you might want to
AND all the TC signals. And you should AND all the TCu signals
together, as well as all the TCd signals to flip at 000 instead of 999.
Again, read the data sheets. They tell all.
I don't see any provision to ensure that the output of the J-K FF will
power up in the right state. Due to the perverse nature of inanimate
objects, you should have a startup pulse to ensure it starts counting
in the right direction. This startup pulse can also clear the '193
counters. You do want to power up with the initial count at 000, and
the initial count direction being up.
Also, the LS76 is a bit of an odd beast -- if this is being used for
high speed stuff, it's better to use something else if you're not sure
about setup and hold times. It's sometimes better to avoid that IC
unless you really know what you're doing, and need exactly what the
chip provides.
But sometimes, it's best just to try things and see what happens. If
your circuit doesn't do what you want, just reread the posts, look at
the data sheets, and change a few things around. It's a good way to
learn.
Good luck
Chris
Bart
chip provides.
learn.
Good luck
Chris
Thanks Chris,
There were many flip-flops available in the simulator, I downloaded about
every datasheet. D-style, J-K, 3-state, etc. and noticed distinctions such
as leading edge, trailing edge, synch, asynch, etc.
With my minimal background, all I figured was this would affect my max
clock cycle time, and affect the transitions at full count and empty count.
I wasn't worried about the additional clock pulses anywhere during the run,
as long as every LED lit up in order and completed the full count both ways.
I chose the 4071 F-F simply for its "toggle" feature. A more detailed
explanation of my goal is to have a circuit that allows me to plug in any
logic gate IC into a socket, then fire every combination of any/all pins,
(except Vcc and Gnd which are powered separately) simultaneously monitoring
all pins for outputs going HI.
I've got several I/O circuit boards consisting of many I/O logic chips
only. I've got one good board and several bad boards, all the chips are
discontinued (old 15Vcc chips) and unidentifiable. My finished design will
utilize an IC clip
http://www.mcminone.com/product.asp?catalog_name=MCMProducts&product_id=22-665
instead of a socket and I'll place it on each chip on a board and run the
design through its full counts, noting which pins output HI and what
combination forced it HI. There are multiple occurrences of the same chips
all over the board and I'm hoping this design will help me discover which
ones are bad.
Thanks for taking the time to read this and if anyone has further
insights/comments they are more than welcome.
Bart
Rich Grise
chip provides.
J-K flip-flops can do amazing things, if the designer can figure out
how to string them together properly. (i.e., you have to be smarter
than the chip. ;-P )
Cheers!
Rich
