I have a number of circuit cards that are failing and this could possibly be attributed to a design problem.
The circuit consists of a +24VDC supply, connected to a 100 Ohm 1/4W resistor which is connected in series on the input side of a 7805 voltage regulator. Measurements indicate approximately 13-14V dropped across the 100 Ohm resistor and 10VDC input to the 7805 and 5VDC output from the 7805. The load draws approximately 170mA from the output 7805.
The problem is: the resistor that is connected in series with the 7805 appears to be showing signs of heat stress or blown altogether. Is the resistors power rating too low, or is the resistance value incorrect for the 170mA current draw.
