8051 Reset with membrane keypad
mpm
Have not tested it yet, but figured I would ask....
Can an 8051 be reset directly with a membrane type switch?
Specifically, the Atmel AT89S52 (but at some point the design /
availability could mandate some other 8051 derivative part, as yet
unknown.)
I plan to use a 4.7k / 1uF combination, and simply take Pin-9 high to
reset it.
For this particular type of project, I would normally use a uPC that
either has internal power-up reset on-chip, or maybe even an outboard
device like a DS1232 or something.
BUT, if it's acceptable to just use an non-debounced, unconditioned,
membrane switch to reset the uPC, this particular design could benefit
from the reduced parts count. Note that I would probably also use a
software watchdog, and I believe the AT89S52 has a power rail monitor
for brownout already built-in (which would also have been provided by
a DS1232 or equiv.)
What do you think?
Eeyore
unknown.)
reset it.
a DS1232 or equiv.)
What do you think?
I think it's fine.
Include a low value resistor in series with the switch to limit the
discharge current from the cap.
1uF sounds a little low btw.
Graham
Martin Riddle
unknown.)
reset it.
a DS1232 or equiv.)
What do you think?
Sounds like it will work, watch out for external noise that could reset it for you.
You could also use a software reset, jump to 0x0000.
Cheers
