Hi SM2GXN & Audioguru,
I actually measured it by "Sound level meter"
It is a little 4 inch speaker that has a max continuous power rating of about 10W to 20W RMS.
If it gave 85dB at 1m with 1 Watt input then it is not sensitive.
Watts ratios can be calculated in dB:
3dB is half or double the power.
5dB is 0.316 or 3.16 times the power.
10dB is 1/10th or 10 times the power.
So 100W is 20dB louder than 1W. If the speaker could survive that much power then the loudness will be 105dB. I bet its voice coil will glow red hot at 100W just before it melts.
No. The max continuous RMS power for little 4 inch speakers is only 10W or 20W.Mukhalled said:So it means that the max power of the speaker is 100W and the RMS is about 20W, right?
Hi Audioguru,
This is an example of a 16,5cm car speaker (the same shop which i've bought my speakers from). As you said "A speaker might be able to handle 100W for only a few milli-seconds, ... " so in this case, this speaker might be able to handle 200W for a few milli sec.
