87 Pontiac revisited (bit long, but detailed)
Hi;
Yup the same one. Still fails on NOx.
We have basically checked everything. The EGR was tested by not only
false triggering it by ground the solenoid wire, it was also removed to
check for free flow when open and proper sealing when closed. This a 5
wire type, so it has a position transducer so if the computer told it
to actuate and it didn't, it would know.
The IAC was checked the most functional way I can think of, turn key
on, then unplug IAC, start engine. It will idle high, plug in IAC with
engine running and RPM drops. It was A OK.
Had a MAP sensor handy so just changed that. Put in a brand new O2
(lambda) sensor.
Now it achieves closed loop operation and after the codes were cleared
has not set any new ones.
Still fails on NOx !. So we put a new cat on it, and it STILL fails on
NOx !
I am starting to think the problem is caused by excessive cylinder
imbalance. That either by partially clogged injectors or vacuum leaks
one or two cylinders are running too lean.
The way I explained it to my buddy is this : When you got a lean
cylinder you get NOx and HC, on a rich cylinder you get HC and CO.
Mixing these two in the exhaust does not make them go away.
At least that is my reasoning at this point. There is really not much
else I can think of. You ?
I am leaning toward vacuum leaks because the car has good power and
even though the idle is not perfectly smooth, it does not have a clear
miss. Off idle or under load it smooths out perfectly.
The other thing is that it does not read all that low on HC and CO. It
doesn't fail, but I have seen alot better readings from cars that run
this good. Especially with a new cat.
In fact my Dad's car which has the 3.1 version of the same engine read
better with a totally blown out cat. It was replaced because it got
loud, not to make it pass, it had already passed.
Now I do remember how they used to check for vacuum leaks, by spraying
starting fluid on the suspected areas. Is it still done this way ?
Should I disconnect the IAC while doing this ? That would seem logical.
There is one other thing. Cars still jump time. If the cam lobe design
is anything like what the norm used to be for a passenger car, jumping
a tooth would actually increase real compression, and lower average
vacuum. Given the conditions, I think it is a real possibility. IIRC,
the system in this car does not use a cam sensor because it does not
need it. Firing the injectors 3 by 3 and having 3 coils it simply
doesn't need a cam sensor. Firing the coils 2 by 2 andf the injectors 3
by 3 there are waste sparks as well as waste (kinda) injections.
On a more advanced engine like a 3.8 it needs both cam and crank
sensors because the injectors are fired seperately. These engines can
detect an error in cam timing but not a 2.8/3.1. I remember my other
buddy with one of the last 2.5 "brick shithouse" engines that jumped
time. It would run, so he takes it in to Mr Badwrench and the machine
that costs the national debt said to replace the engine.
I looked at it and after much pondering told him "tear down for timing
chain". Later he showed me the almost non existant tensioner and the
chain with the burrs all over it. After a set of timing irons (my pet
name for the chain and tensioner and maybe gears) he was back in
business.
To support that theory, the 2.8 has very little backpressure at idle. I
mean even with the EGR tube open it is not all that loud. I took it off
and pulled the plunger manually and I just didn't think there was
enough coming out of it. That is, however, a subjective judgement.
Since it is in closed loop without an EGR code, I can only assume the
plunger is moving when told to by the computer. We are sure it is not
clogged. We are also sure the EGR is not leaking.
So what, in your opinion is the better way to go ? Spray for vacuum
leaks, check cam timing or look seriously at the injectors being partly
clogged. The idle sounds a but like a lean misfire, and the power is
good and smooth under load. By my reasoning the idle is affected more
than the power range. Doesn't this point to a vacuum leak more than
injectors ?
If someone is going to up and say "injectors", would injector cleaner
be a good idea ? Normally I avoid it like the plague. When the engineer
designs those injectors there is a paper that says what they are to
inject, and there is one word there ; gasoline. I also shun injector
cleaner because when the injector is really clogged, the cleaner will
never get to it. However there is always an exception. These do fire,
but perhaps flow is decreased in a couple of them.
In a 3.8 I would take and ground each injector line from the computer
and see how much it takes to flood any given cylinder, but they are
wired together in two banks in the 2.8/3.1 so there is no easy way to
do that. There are only two wires at the computer and you can't really
get to the other end because they have the top plenum over the
manifold.
Anything helpful is greatly appreciated. This guy is just back to work
and has to drive all over the place. He has to periodically go begging
for license plates and/or like last time, sign the car over to get
another temp tag. We let him use a spare set of plates for a few
months, but we got rid of the car and it would have to be tested to
renew them. With the new parts and the new cat, even if he could afford
another car right now, that would waste everything we put into this
one. He does construction labor and this being a station wagon, it is
the perfect work car for him. It's a breeze to drive compared to a
truck and on the rare occasion he has to carry a ladder it will work.
It locks and his tools fit.
We are getting to our wit's end here. We have even considered some
skullduggery, like running it on pure ethanol for the test, or even
test driving a car with the same engine and real quick switching the
enigines and returning it. We don't want to do either. When I was a kid
we would consider stealing a car and popping the engine in it, but no
more. I/we don't want to do anything like that. Getting caught is not
the problem, we could get away with it, but we do not WANT to. It is
immoral. Well the ethanol isn't but that doesn't help him when test
time comes around next year. We are in our 40s and want to do things
right. There is no good reason this thing cannot pass.
Well there is, but we are having trouble finding out what that reason
is.
Anyway, don't you just love my posts ? I know how it is. As much as we
tell people to be thorough and give details as to what you have already
done/tested instead of "Da thing don't work", I seem to be at the
opposite end of the spectrum. Sometimes at work I am called upon to
help another tech, and sometimes I say this, they reply "checked it", I
say that and they say "Replaced it". While that tells me they are doing
something, it doesn't make it any easier.
So as you read my post and are about to say "______" and the next
paragraph tells that I already did, don't get discouraged, please.
The other thing is that I think of time as money, not that I need pay.
This is almost a personal challenge. Like I said the guy is just back
to work, I bought the cat. I'll loan him the money for gaskets, but do
we need the intake set or the timing case set ? Actually he has a 30
day now, by the time it runs out he'll have a check, but I still do not
want to steer him wrong.
What, in a way, I really need are ways to definitively check these
things without a teardown. Got any ? For example, can someone say that
at a certain reading of the timing marks (if any) that a certain valve
under the front valve cover should be fully open, like at the peak of
the lobe ? Or is there a way to plug up the exhaust and pump air into
the intake to detect leaks ?
I am always looking for new ways to test what is seemingly untestable.
Pros have a few tricks, some of which they'll give up, others maybe
not. For example I have extreme shortcuts when it comes to fixing TVs.
We need that to make money.
I din't want to make this too long, but I have had to adapt to figure
out how to find the fault in TVs that are almost impossible to service.
The scope is the first thing for me. Dead set, got SMPS standby, put
probe near transformer. see RF ? move on to main SMPS and turn on, run
for a sec and shutdown ? Get to the flyback, but set to 10uS triggered.
See a five fingered waveform ? Bam, throw in a fly and wipe it's ass
and ship it. By wipe it's ass I mean give it a tuneup, clean the lenses
etc. and touch up the convergence. Auto diagnosticians surely have the
same shortcuts.
For example what alot of people don't know is before you buy a high
mileage car there is a test. Take the oil filler cap off and put a
piece of paper over it. It should stick at idle. There should be vacuum
there. If it is blowing out the engine has compromised sealing of
compression to crankcase. Don't pay alot for it, it is worn out. I do
this before even thinking of looking at the odometer. I know a few
things having been around cars alot, but the pros know more. I even
know about the brand new defective radiator caps, that thingy in the
middle should be spring loaded to the rubber seal. In some cars this is
very important, especially bigblocks, if you happen to still have one.
Kinda what I am looking for is how to check what. On the other side of
the screen I know you can't troubleshoot it from there. I seem to be at
a loss for testing techniques at this point. If someone can just up and
tell me what the problem is it would be great, but I don't really
expect that. Also, better techniques will come in handy. As cars get
more and more complex it ain't getting any easier.
Anything you got is very appreciated. Give me your address and I will
at least send you some beer, if you want it. This is just one of those
important things to get done, and it has become somwhat personal. I
can't let it win. If it only knew that if it wins it goes to the
crusher :)
Everybody have a good year. I await your wisdom. Now I am off to scan
the recent posts to see if I can spead some around, in the spirit of
"pay forward".
Have a good one.
JURB
Ancient_Hacker
To test for a vacuum leak, just run the engine at idle and spray all
over with anything flammable-- WD-40 is probably the safest. I wouldnt
spray starting fluid, it's a bit too quick to evaporate and mighty
explosive and intoxicating too. The old VW Rabbits would get
hardening of the injector grommets and leak like crazy-- five seconds
of spraying and you knew for sure they were leaking as the idle would
speed up whenever you sprayed.
To test the injectors, pull the wires off them one at a time. No wire
means no injection which should result in lots of engine vibration but
the NOx should drop if the injector's been faulty.
Is the engine hard to start after it's been sitting off for a few
minutes? That might point to drippy injectors. A can of injector
cleaner can't hurt to try.
Good luck.
W
webpa
Good luck.
Been through all this with an '86 Fiero. Flushed, adjusted, then
replaced EVERYTHING...every sensor, vacuum hose, valve, and device...to
no effect. In the end, it took a new catalytic converter...which cost
all of US$86, installed. By Midas Mufflers. About 1/4 of what I'd
spent on the other parts. So: Don't jump to conclusions.
M Berger
That's less than the price of a decent catalytic converter,
and Midas is usually very high on labor costs. In fact,
our local Midas quotes $ 300 and up. I wonder what they
really did to your car?
W
webpa
Replaced the converter and about one foot of pipe with a generic
small-engine unit (parts cost ~US$50). I still have the old one.
Engine then passed the emissions test with better-than-new-engine
numbers for CO, NO, and HC. Has passed each subsequent test (4 of
them) with the same results. Maybe I hit Midas on a slow day?
Thanks folks. I completely forgot about the injector seals.
Will spray for leaks using WD40 with the IAC disconnected.
Unfortunately it is impossible to disconnect each injector seperately.
There is a plenum in the way. Even if the wires come out seperately, in
this car they are hooked up three and three, I have really never
examined the harness to see, but it doesn't matter, to make any
injector specific test I believe a bunch of wires would have to be cut.
Save that till after we get alot closer to the BFH. I would not want to
sit there crimping wires back together. And believe me there is no way
to get to the plugs right on them.
I also thought of doing an RPM drop (or vacuum) check by disconnecting
plug wires, but they made that a PITA too. Not real bad, but you need a
screwdriver or something to ground the coil output during testing,
otherwise the cylinder opposite from it in the firing order will lose
firing voltage resulting in erroneous readings. This is because the
three coils' secondaries are completely floating.
As much as I like these late 80s early 90s EC management systems they
do have some difficulties in troubleshooting at times. I like it when I
am in a hurry and can just turn the key and drive even when it is 0
degrees outside. My 87 hasn't stalled for years unless something else
screwed up. Within about 40 seconds of running there are days it hit
5,000 RPM to get on the freeway (I live real close).
I think it is wonderful, the ECM system in these GMs. It is like having
a competent engine engineer under your hood at all times, and he is
busy. Constantly adjusting timing, even the setting of the weight
springs in the distributor. Constant control over the choke, well the
ersatz choke, and constantly adjusting not only the screws on your
carb, but changing the jets while you drive down the road.
Yes, it is wonderful. I think it is even more wonderful that Bosch did
it without electronics. But when it screws up, people are alot less
happy.
Anyway, in the responses thusfar I didn't see anyone take the wind of
the timing chain idea into their sails. Kinda glad.
Gonna go spray for those leaks and get back to you.
Thanks again.
JURB
Also, cats are not as expensive as they used to be for regular cars.
The one we put on was $36 brand new in the box.
A place like Midas probably buys by the truckload, so they might pay
say $25. If they charge you say $80 installed, they made $55 in about
20 minutes. As long as there were no other complications, you would've
been charged for them as well. The mechanic probably makes between $15
and $25 an hour. This should be billing at 3X that. It might be more in
this type of business because it can be high maintainence. Three X is
just a rule of thumb though, high cielings cost energy in the winter at
least, and mess with the bottom line.
Last cat I had put in a car was $100 at the local muffler shop, but
this was a couple of years ago. It seems there is a new manufacturer or
something out there.
JURB
Bob Urz
JURB
You would be hard pressed to get a muffler for that much money ($25).
And a cat is full of rare metals (at least a real cat does)
You might find some generic cats (usually Pre OBD2) after market for
a more reasonable price. But they are generic with no ends (flanges)
welded on and no ports for O2 sensors.
Factory fit out of the box cats are usually in the hundreds of dollars
Meat Plow
A direct fit Catco for an 87 Grand Prix is $109.00.
W
William R. Walsh
Hi!
I remember this.
NOx !
Hmm, maybe a move to where emissions testing isn't commonplace is in order?
Yes, I believe it is. I also seem to remember hearing of carb cleaner being
used this way...but both are rather volatile substances. WD40 isn't quite as
volatile, but it is safer.
Worth a check...what can it hurt since you've done just about everything
else by now?
It's worth a try. Get some injector cleaner and run it through the car. It
might make a huge difference. Here's a little story you might want to take
the time to read. I may have mentioned when you first posted about this car.
But if not, read on:
My dad bought a 1988 Buick LeSabre (3800 V6) for $100. It didn't look bad
and rode well, if it ran long enough to get up to speed. When we started it
had gas in the oil, many cylinders not firing and a service engine light
that wouldn't go out. The previous owner had driven it until it would run
reliably any longer. My dad drove it home, which was an adventure. We didn't
have any better way at the time. No trailer we had was long enough, so it
was followed with a "chase car" in case of problems. A mechanic said "junk
it and cut your losses".
Well...I don't think that way, and neither did anyone else involved. We
started fixing problems...fresh oil and filter, new plugs, plug wires, and a
spark module (as we still didn't have fire on at least one cylinder) were
all installed and they made quite a difference. But something still wasn't
quite right. The engine light was still on, and it didn't run like it
should. It was hard to start as well.
So one night, with only a little gas in the tank, we put in some
Lucas-branded fuel injector cleaner. (Come to think of it, we might have
actually put in more than one bottle, as this seemed serious and we were
desperate.) The mix was way too strong, and we all kind of wondered what
kind of abuse this might inflict on the fuel injection and pumping system.
Now, it was about 11 o'clock at night when we started this car in the
driveway with virtually no muffler left (the entire *top* of the muffler was
gone) and let it rip. It bucked and snorted something awful at first.
Finally, after about ten minutes, the cloud we were making subsided, and the
car evened out nicely. Thankfully, our neighbors are into playing with cars
as well.
The engine light turned off in the strangest way. After the muffler had been
replaced, the light was still on. It went out and never showed up again (nor
did any codes) after we put the final little elbow piece on the back of the
pipe leading off the muffler. Who knew the engine computer could be that
sensitive?
After all that, the car ran fine for several thousand miles until the fuel
pump failed. And that's where we've left it for now. Nobody (myself
included) has had time to do any more than drop the tank off the car, as all
the fuel line was so rusty that it fell apart.
So that's the story. (As for the bit about the Lucas fuel injector
cleaner...it seemed to work, and I've met Mr. Lucas himself. He's a
genuinely nice guy who believes in the stuff he sells. No, I have no
affiliation with the company or its products other than as a satisfied
customer.)
http://www.lucasoil.com/
immoral.
I get the feeling there may be a story here...care to share it? I agree that
isn't right, but it would be pretty funny. And if I'd done that, the new
engine would act the same way!
I tend to agree with that.
Sure, it was an interesting read. I well remember the original post, and
might have replied to it.
there.
Thanks for the info. That's an interesting idea...I'd never thought of that.
Give me your address and I will at least send you some beer, if
you want it.
No need. Hopefully something I've said might make for a path to the
solution. If it does, so much the better. I'm no automotive expert by any
means, but I'm not afraid of them either...having changed starters,
flexplates/flywheels, fuel tanks, oil and other stuff.
William
Roger Delkin
wrote in message @v33g2000cwv.googlegroups.com:
While reading the description of your problem, I was thinking, "clogged
injector(s)." I had an '88 Pontiac Grand Am, different engine but the same
basic fuel and ignition system. I kept the engine well maintained even
though I didn't care so much for the suspension, body, interior. . .
ANYway, the car ran pretty well until I loaned it to a friend, who
apparently was buying the cheapest gasoline possible. When he brought the
car back to me, it was stuttering, had to start, rough idle, but still had
somewhat reasonable power. I ran a few diagnostics and found that the
injectors were indeed firing (used an oscilloscope on the wires into the
injectors). The problem was solved by removing, cleaning, and reinstalling
the injectors (don't forget new seals). Note that the liquid injector
cleaner may or may not fix your problem; you may have to R&R your injectors
to really get them clean.
I sold the car soon after with 246,000 miles on it, not bad considering I
pretty much always drove it like I stole it. It was shipped down to Mexico
and placed into service as a taxi. Really!
~RD
Beloved Leader
I am dropping in without knowing much about what is going on here. I
just wish to add this:
It was thought for a while that I might have a leaking intake manifold
gasket on a Y-code 307 V-8 in a 1989 Oldsmobile Custom Cruiser. I tried
spraying WD-40 at the seams, to no avail. A trusted technician at the
local Cadillac dealer said the stuff to use for that pupose is
carburetor cleaner. That will ignite, causing the rpm's to bump up as
it is sucked into the cylinders. I did as he suggested, and the rpm's
did increase. It turns out that the manifold gasket was not at fault.
Rather, there was a disintegrated thermal vacuum switch adjacent to the
suspected bad spot in the gasket. Replacing that cost a few tens of
dollars and a few minutes, not several hundred dollars and several
hours. It was quite a relief.
My vote is for carburetor cleaner.
David Lesher
Better is a propane torch. Not lit, just cracked open. When the
leak such propane, the car runs far smoother.
David Lesher
......sucks....
