900MHz beat freq. transmitter
Mark Langley
Can anyone advise what type of equipment would be needed to create a
_localized_ beat frequency (standing wave) on the order of a few KHz
by engineering the phase relationship between two 900MHz PWM carriers?
What degree of oscillator stability is implied?
Mark Langley
F
Fred Abse
Mark Langley
Homework?
W
Winston
That would depend on your requirement for beat frequency stability.
The following is just an illustration and is a bad
practical approach WRT stability (see last line):
The Crystek CVCO55CL-0805-0900 will move it's output
by 30 MHz for every 1.0 V difference on pad 2 (Voltage Control Pin).
This would require you to hold the control voltage variation below
300 nV pk-pk to stay within say +- 6Hz stability of your beat
frequency, provided that your reference oscillator has *no*
instability or drift. Even then, you would probably require
a crystal oven and super regulated supplies for both oscillators
to get that level of performance.
V(high)=2.50000000 F = 852.906000 MHz
V(low)=2.4999997 F = 852.905990 MHz
F(ref) = 852.900995 MHz
F(highbeat) = 5005 Hz
F(lowbeat) = 4995 Hz
The actual stability would be worse because the part
imposes (for example) a 1 KHz phase noise of about -79 dbc/Hz.
--Winston
