9014 Direct Replacement???
bigkim100
Apr 17, 2013
270
Ok, simple question, I have a 9v circuit that flashes a led. The output of the LM358 is a 9014 transistor. I want to add more LEDs but the 9014 gets a little warm....is there a power transistor that can directly replace it????
Martaine2005
May 12, 2015
5,276
You could try a 2N2222 NPN.
It should give a few more mA.
Failing that, an N channel mosfet or a relay.
Show us the circuit and somebody will be able to give you a more precise answer.
Depending on the LED wiring configuration, you may be able to run more on your existing circuit.
Martin
bigkim100
Apr 17, 2013
270
Here it is, its not very exacting as far as components go
bertus
3,835
The schematic is VERY small.
I can not read any values.
Bertus
Audioguru
Sep 24, 2016
3,656
Your schematic is too small to see its details, but it looks like the dual opamp is a triangle wave generator driving the transistor as a linear emitter-follower. Then of course the little transistor gets hot and so will any little transistor. Add a power transistor to drive your bunch of "breathing" LEDs and the little transistor can drive the power transistor. With many LEDs then the power transistor will need a heatsink.
Use a decent mosfet and you can add the LEDs till the cows come home.
Audioguru
Sep 24, 2016
3,656
The transistor here is used as an emitter-follower. If an N-channel Mosfet is used then its gate must have a fairly high voltage for it to be a source-follower.
It has me beat why they insist on switching on the high side.
So simple to use an n-channel mosfet ( logic level if required) and take the LEDs to ground.
Martaine2005
May 12, 2015
5,276
I think this circuit slowly dims and brightens the LEDs rather than just switching on and off.
Martin
Audioguru
Sep 24, 2016
3,656
The dual opamp creates a triangle waveform that slowly brightens the LEDs then it slowly dims the LEDs. The transistor is an emitter-follower that is linear (not a switch) so it gets hot.
bigkim100
Apr 17, 2013
270
Do I drive the NChannel Mosfet from the existing transistor, or directly from the IC
Audioguru
Sep 24, 2016
3,656
Here is the tiny schematic posted and a larger one from Google. The transistor cannot be a Mosfet unless you use a much higher supply voltage and change some resistor values. Use a power Sziklai follower.
Martaine2005
May 12, 2015
5,276
I had to Google that, thank you.
For anybody else interested here.
@Audioguru can you please explain how that works?.
The darlington is the same pair and this is a complimentary pair. Q1 collector is connected to Q2 base, that confused my little brain.
Martin
Audioguru
Sep 24, 2016
3,656
As a follower, the Sziklai pair has half the voltage loss of a darlington but it has the same current gain.
Martaine2005
May 12, 2015
5,276
Ok, I still don’t understand.
With the collectir of Q1 to base of Q2, sorry I can’t get my head around that configuration.
Perhaps you could explain in layman terms please.
Martin
Audioguru
Sep 24, 2016
3,656
The collector of the NPN turns on the base of the PNP. The PNP is a power transistor on a heatsink so it can have a high output current.
