A 8086 embedded board
  • Thread starter Antonello Pasella
  • Start date
Antonello Pasella
where I can find a 8086 embedded board?
I need a small RAM (1,2 Mb) an IDE interface and some serial/parallel I/O.
I'm not looking for VGA or Ethernet and so on, maybe a keyboard and a mouse
(ps/2 or serial)
tkz in advance! and good new year! :)
Michel Catudal
mouse (ps/2 or serial)
Look for an 80C186 board, you may have better luck. They are advertized
in many of the magazines that I get at work.
apaella
Its good idea to ask yourself why to use 8086 as most todays chips (or
even old chips) are much easyer to use than 8086. If you do not need
compatibility with PC software then other chips are better solution.
for example?
I need only a good and simple C compiler with a library for ATA & FAT32
access and quite then 2MB of RAM.
Not SMD solder please :)
I've found a Z80 IDE adapter but I'm not able to found a library...
SOme suggestions?
