A chock coil
walid1
Jun 27, 2004
749
In many FM Txs they use a coil connected from the o/p of a high frequency stage to the power supply, this coil is of fairly larg value (for example 100uH). The purose of using such coils is to chock (prevent) high frequency sigals from going to other stage through the power supply.
For example in 100 MHz FM Tx, they use 100 uH coil which has impedance of (2*pi*f*L) about 63 Kohm.
My question: Is it better to use 1 mH (1000uH) which has 630 Kohm ot taking the size into account?
Or is this true:"the more L the more chock effect"? What are the limits?
thanks.
audioguru2
Apr 6, 2004
12,026
Hi Walid.
It is called a choke, and if its value is too high then the capacitance between the layers of windings might be so high that it parallel resonates at a lower frequency than you want. Above its resonance it behaves like a capacitor instead of an inductor.
Staigen1
Oct 26, 2003
695
Also, isn't a 100uH choke a little bit high at 100 Mhz?
//Staigen
Staigen1
Oct 26, 2003
695
Hehe :D :D
Isn't that a typo, should be nH instead? ???
//Staigen
audioguru2
Apr 6, 2004
12,026
The circuit's author likes big values. Look at the huge value for the emitter bypass cap. It would still work very well at a frequency 200 times lower.
walid1
Jun 27, 2004
749
Hi audioguru and Staigen
How you think calculate this value, this what i need to know
gesign gesign gesign gesign gesign gesign gesign gesign gesign
Staigen1
Oct 26, 2003
695
Oops! isn't that also too big, i belive that a cap that big at this freq lives a life of its own, and dont decouple the emitter resistor very well! Something else curious with this schematic? Of course, no emphasis! Maybee thats why the coupling cap between the mic and the input is so small! Moore?
//Staigen
audioguru2
Apr 6, 2004
12,026
With a small coupling cap so it doesn't have any bass, and no pre-emphasis so it doesn't have any treble, then it would sound much worse than an old telephone. 8)
Staigen1
Oct 26, 2003
695
Hi Walid
Thumb of rule: Not moore than 1 nF at 100 Mhz for decoupling! This goes for toobz, but i think it is relevant for transistors too, it dont have to do with if it is a transistor or a tube.
What is "gesign"
To Audioguru: Hehe :D
//Staigen
audioguru2
Apr 6, 2004
12,026
Until you are experienced in circuit "gesign" it is advised that you build a "bototype". (He, he.) ;D
Then you can tweak parts values in the prototype to make it work as well as it can.
In the prototype you will learn that 100MHz is a very high frequency.
At such a high frequency, you will learn that 100nH works well, but 100uH works like a capacitor.
At such a high frequency, you will learn that a 1nF ceramic cap with short leads works very well, but 100nF is an inductor. ;D
walid1
Jun 27, 2004
749
I have not oscilloscope or other devices to monitor the change so i ask
audioguru2
Apr 6, 2004
12,026
Without proper test equipment you will be working blindly.
Aren't you the guy who wants to be an expert circuit designer? I have never seen a blind expert circuit designer. :(
It is fine for you to ask about the details of design, then you will learn from us. ;D
walid1
Jun 27, 2004
749
No problem I talk with a designer from USA and he told me that he rarely use the oscilloscope, the understanding more important than instrument or come first.
yours
walid
