Hi
I have a SMPS that its output varies from 4V up to 32V. As you know at the output of most SMPS there must be a Load to Dissipate some power. For my SMPS, it should be at least 2-3W Because this SMPS is to be used as a Laboratory Supply, I have to put a load at the output. I can not use a single resistor.
i.e.
Vi = 4V & R=8ohm ---> P=V^2 / R = 2W
But if Vi = 32V then P= V^2 / R = 128W
So I have to use a constant power consumption circuit. I designed one but it dissipate 8W at Vi=18V and dissipate 2-3W at Vi =32V and dissipate 3W when Vi=4V.
I have not build it yet. These writing are from my calculates.
This Non-Linearity is because P is proportional to Vi^2.
Does anybody have a good Idea?
The schematic is attached
My numbers are not very Sharp
ThanX
Shahriar
ConstantPower.pdf
i.e.
ThanX
Shahriar
ConstantPower.pdf
