A Funny Thing Happened on the way to this circuit
SparkyCal
Mar 11, 2020
863
I created a circuit that utilizes a 555 timer that flashes a bank of blue LEDs driven by a 12 volt battery
It works fine. Then I had the bright idea, of creating another bank of LEDs- this time using a yellow LED, and daisy chaining it to the prior LED bank, in series..
My thought was, it would simply cause both banks of LEDs to blink.
But I am finding that it is either one or the other. Both banks will not blink at the same time.
I am sure there is some sort of principle I am not understanding, and violating. Can someone give me a clue?
Thank-you
bertus
3,882
As always, when you have a question, post the schematic.
Can you draw a schematic of the set-up?
Bertus
SparkyCal
Mar 11, 2020
863
I can't draw a schematic yet, but this is what i can do. Here is the circuit I am working with:(see attached. )
I also hand drew the LED banks and their connections.
bertus
3,882
Do you have the specifications of the leds?
When the leds do not need serial resistors, aka 12 Volt leds, they should light at the same time.
It is not a good idee to put classic leds parallel.
A classic blue led would need 3 to 3.5 Volts to work.
A classic yellow led would need 2 to 2,5 Volts to work.
Bertus
SparkyCal
Mar 11, 2020
863
Yes I do Bertus. The blue LEDs are 3.oV-3,4V 20mA. the yellow are 1.8V-2.4V 30 mA.
bertus
3,882
  • Led color chart.pdf
SparkyCal
Mar 11, 2020
863
Thank-you. i think you nailed the problem. I failed to realize I was working these banks of LE Ds in parallel. I had assumed, it was i. series. But your observation makes perfect sense. A few solutions are now becoming apparent. Thank-yopu
Just be aware the 555 has a maximum current limit of around 200mA.
SparkyCal
Mar 11, 2020
863
Thanks. I have reconsidered this and decided not to introduce a second bank of LEDS. But I learned something from this, do thanks for that,
When you get in to high power LED's , constant current /voltage drivers can be an advantage.
Martaine2005
May 12, 2015
5,318
LEDs can be connected either series, parallel or a combination of both depending on the circuit and voltage available.
There is a great resource section on this forum here , that will explain all you need to know about LEDs.
Martin
Martaine2005
May 12, 2015
5,318
BTW, top is series and bottom is parallel.
No need to ever ‘assume’ again.
Martin
Audioguru
Sep 24, 2016
3,656
My cheap Chinese flashlight has 24 white LEDs in parallel and it works fine. All the LEDs must have been tested and grouped into groups having only one matching forward voltage. The forward voltage is about 3.2V and if a few 2V red LEDs were additionally in parallel then the red ones would light up VERY brightly and the white LEDs would not conduct and produce no light.
