A Little Delayed in Starting
SparkyCal
Mar 11, 2020
863
I am starting a delay circuit for my guitar pedal, thanks to the nudge from VB.
I received the PT2399 Chip ( actually, I have 4 of them).
I am tempted to breadboard this first, but breadboarding. gets a little hairy- especially with all the wired and stuff. So, I am considering simply going to PCB.
The schematic can be found on this thread:
#101
It is the project in the data sheet entitled Suround/Delay. Direct link to data sheet is here: http://www.princeton.com.tw/Portals/0/Product/PT2399_1.pdf
SparkyCal
Mar 11, 2020
863
Thanks Bertus. While I can’t pretend I understand what each component does, the explanation on Peter Vis’ site provides a good idea of how things interrelate and play a role within the chip and in the circuit. I will read it again. It’s helpful. I did t know you can have a digital and analogue ground
SparkyCal
Mar 11, 2020
863
I don’t have a socket for this chip. Is it possible to place two 8 pin op amp sockets together to act as a 16 pin socket?
bertus
3,874
Yes, you can use two 8 pin sockets to stack an 16 pin chip.
Just put them close together on the board.
Bertus
SparkyCal
Mar 11, 2020
863
Thanks Bertus. I just t=noticed, I thought I had 4 of these chips, but on closer look, it came with two chips and two sockets- so I should be good. Good to know for future reference though.
SparkyCal
Mar 11, 2020
863
Hmm..my first question- this circuit seems to be powered by 5v. How do I achieve that if it is to be powered via a battery? It would be impractical to power it with a variable power supply.
VenomBallistics
Aug 30, 2018
285
https://www.electrosmash.com/pt2399-analysis
Further information of the PT2399 ... You shouldn't need much more than the datasheet example until you discover some of the quirks ... then the pin 6 strategies may come into play.
I have a dozen of these chips and sockets, as well as some multiplexers and kinky power management stuff.
This coupled to a head full of ideas ... this might be a fun thread
SparkyCal
Mar 11, 2020
863
I would like to build this first and get it to work using the 5v from my variable supply, rather than get another chip right off the bat.
SparkyCal
Mar 11, 2020
863
Fun for who? Lol
SparkyCal
Mar 11, 2020
863
this guy seems to suggest that it will not work if built according to data sheet, but I have to think he’s wrong.
bertus
3,874
The datasheet shows that the normal oprating voltages are between 4.5 and 5.5 Volts.
As said you can use a 7805 to regulate the voltage to 5 Volts.
One thing, the 7805 needs at least 7 Volts to be able to regulate.
A LDO regulator like the LD1117-50 needs about 6 Volts to be able to regulate.
Bertus
  • LD1117XX.pdf
  • LM78XX_ni.pdf
SparkyCal
Mar 11, 2020
863
Naive question: Can't we just use a step down resistor to lower 6 volts from batteries, to 5 volts?
VenomBallistics
Aug 30, 2018
285
Part right. Electrosmash has documented the chips quirks.
Pin 6 is the primary means to adjust clock speed ... AKA delay time.
Fast clock speeds (short delay times) cause it to choke if powered up while set to such speeds.
Since a reverb would be such an application ... the sucka gonna hang.
Longer, lush echos will be fine.
VenomBallistics
Aug 30, 2018
285
how about 3X AA batteries? (1.5 X 3 = 4.5V)
It'll get you started until you migrate to LM7805 regulators. then it's pedal board friendly in 9 out 5
SparkyCal
Mar 11, 2020
863
I have another question, and it is important for me to understand- although it may sound simple. Attached is a pic of the circuit we are building. You will note that I labeled (in pen), parts of the circuit with 1. 2. 3. and 4.
Here is my question:
On my PCB build, I have a Pin that I soldered in. The purpose of the PIN is to connect the + 5 volts to.
From a practical perspective, the positive leads from the 0.1uF cap and the 100uF cap, are both directly connected to the Pin that I mentioned above.
My question is this- will that way of connecting them work, or does the circuit require that point 2 be connected to point 1 , and that point 3 be connected to point 2.
In other words, does the 100uF cap have to connect to the 0.1uF cap before the 0.1uF cap gets connected to the 5V pin, or can the
positive leads from the 0.1uF cap and the 100uF caps both go to the 5V pin without first having to follow the sequence described above?
Part of me says that they both go to the same place, so what does it matter.
BUT,,,part of me says, maybe it matters the order they go there.
Thanks for any clarification you can provide.
bertus
3,874
The capacitors on the powersupply are decoupling capacitors.
They will provide a stable working of the chip, as the chip is a digital one and can create pulses on the power line.
You can read this thread on the AAC for more info:
Decoupling or Bypass Capacitors, Why?
Bertus
SparkyCal
Mar 11, 2020
863
Bertus
I sort of had a n idea as to their role, but the article made it clearer. However, my question is about whether the positive leads from both capacitors can be connected to the 5v pin at thr same time, ofr whether they need to be done in a certain. order (ie:the positive leads from the 0.1uF cap first and then and the 100uF cap_)
Maybe the article answered that question, but it escapes me. Are you saying that because they serve the decoupling purpose, that they have to individually run to the 5v pin?
