A project, help
vivek_pv
Aug 2, 2006
43
Hi all,
Now I have a project.
Let me tell like this :
1. There is a chip which emits a +5v signal (of very sort span) when one condition is
satisfied. Like a blink.
2. I want to take that "one blink type signal" and switch on an LED.
3. If I use, NPN and give that signal to base, then the ckt will be on as long as the signal
persists.
4. But I want to hold the LED "on" unless anybody resets it.
5. This I have made using relays. (using feedback type)
6. I have tried the same topology using transistors. (Collector to base) but that's not
working.
I am enclosing the schematic. please help.
regards,
v
audioguru2
Apr 6, 2004
12,026
The circuit in your box needs to be a flip-flop. A blink flips it on and another short signal resets it.
vivek_pv
Aug 2, 2006
43
Can you please give me the design of this "flip flop"?
regards,
vivekanand
audioguru2
Apr 6, 2004
12,026
For more than 40 years, when I needed a flip flop then I used a flip flop IC. You can look in Google if you want to make your own.
audioguru2
Apr 6, 2004
12,026
I haven't used an old 7400 for more than 40 years. I made set-reset flip-flops with them but since I have used Cmos and flip-flop ICs. Look for a set-reset flop-flop that uses TTL gates in Google.
vivek_pv
Aug 2, 2006
43
What is the difference between TTL & CMOS in working (as digital gate ics)?
Is CMOS superior to TTL?
audioguru2
Apr 6, 2004
12,026
Google will tell you more than me, but Cmos has a very high input impedance, has a very low supply current, works from 3V to 15V and 74HCxx high-speed Cmos is just as fast as 74LSxx.
I think so. Intel and other computer chip makers also think so.
vivek_pv
Aug 2, 2006
43
Tell me which type of Flip Flop should I use to serve the purpose.
SR F/f with 7400 and 4011 was unsuccessful.
audioguru2
Apr 6, 2004
12,026
Look at "set, reset flipflop" in Google. It shows that a NAND gate flipflop won't work with your high signals, it works with low signals. You need a NOR gate flipflop.
The signals to a gate flipflop must be momentary. If an input signal stays then the other signal won't work.
vivek_pv
Aug 2, 2006
43
Ok.....
But if my set signal stays for 3sec or still longer, then what type should I use.
Another thing the input signal is of +3V.
audioguru2
Apr 6, 2004
12,026
vivek_pv said:
Ok.....
But if my set signal stays for 3sec or still longer, then what type should I use?
Use capacitor coupling. It will give a short duration input pulse no matter how long the input stays. Then the NOR gate flip-flop's inputs also need pull-down resistors.
Then the supply voltage for the gates of the flip-flop should be the same.
Ordinary Cmos gates work with a supply voltage down to 3.0V. 74HCxx high-speed Cmos gates work with a supply voltage down to 2.0V.
audioguru2
Apr 6, 2004
12,026
Gate inputs must be connected to a DC voltage, so I added pull-down resistors for a logic low at rest.
You had the LED connected so "set" would turn it off the first time. I have it so it turns on.
A "power-up reset" circuit could be added.
