Hi guru
The base input impedance of the transistor at low audio frequencies
is its beta of about 200, times the emitter resistance of 220 plus
its internal emitter resistance = 44.5k ohms. It is in parallel with
the two 47k resistors also in parallel, so the load on the mic is
15.4k ohms.
This is good, but I want to introduce the effect of the 1nF cap on the lower 47Kohm.
The reactance of that cap at freqs from 300Hz t0 15Khz is 10.6 Kohm to 53 Kohm
47K // 10.6K = 8.65 K, and
47K // 53K = 24.9K
so VB is not constant at VB = 9 * 47/(47+47) = 4.5v as i was think
it is really changes from 1.4V to 3.12V with the audio freq
Now Zin (total) = ZB//RB1//RB2
since RB2 equivalant is change from 8.65 K to 24.9K
so Zin change
please comment.
It is complicated to calculate how much is the output voltage and current because tapping down
the coil reduces the output voltage into the low impedance antenna but provides a better
impedance match so the collector voltage swing is much higher.
I agree that it is complicated to calculate how much is the output voltage and current, lets
assume them and investigate the tapping effect on them:
If the output voltage = 5mV rms at freq 100MHz as shown in the Fig. below, how much voltage reach the antenna?
and what the value of the impedance the antenna see, if the coil is 330nH and its XL = 207 ohm at 100MHz?
thank u guru
