Rich said:
http://www.abiengr.com/~sysop/images/AAAARGH!!.jpg
(the point is to bus all of the even-numbered wires to ground.)
Cheers!
Rich
Hi, Rich. Let's assume for the sake of discussion you have a 20-pin
ribbon cable. Here's what I've done in the past, after looking at this
same depressing problem too many times:
1) Terminate your ribbon cable with an IDC connector.
2) Scrounge a piece of perfboard at least as wide as the IDC
connector, with three hole-per-pad layout. Cut the perfboard so the
dividing line between two lines of pads runs down the middle laterally.
3) Using 24AWG wire, jumper across from one line of pads to the other,
leaving the closest holes on each side of the dividing line open (in
the diagram below, the jumpers go from the top "X" to the bottom "X").
Have the jumpers extend a few tenths of an inch down from the bottom
side of the board.
4) Solder the jumpers onto the perfboard. Now, using sheer cutters,
cut the jumpers off flush at the top of the board. You should have two
lines of leads coming down from the solder side of the perfboard.
5) Now, solder in a mating IDC receptacle on the perfboard. In the
diagram below, it should be in the holes marked "o".
1 19
| X X X X X X X X X X --Jumper Leads
| o o o o o o o o o o |
| \ IDC receptacle
| o o o o o o o o o o /
2 20 \
\ Perfboard
(created by AACircuit v1.28.6 beta 04/19/05
www.tech-chat.de)
You now have an IDC connector you can easily insert into a protoboard,
0.3" spacing just like a thru-hole IC, and you can automatically plug
one end into a bussed line of the protoboard to have your interleaved
GND.
I've got a few of these lurking around, and dig them up when I need
them for ribbon cable to protoboard work (if you take care of them,
you'll only have to make them once).
Glad to 'ave been of 'elp, sir. Again, thanks for "coming down from
heaven" to enlighten us groundlings. Always a pleasure.
And "keep up the skeer" on s.e.d. ;-)
Chris
