About a Diy pc oscilloscope found on the Net
  • Thread starter Gaetan Mailloux
  • Start date
Gaetan Mailloux
Hello
I've found this pc oscilloscope web page;
http://scopeonpc.tripod.com/adc.htm
Any one try this ADC for pc scope ?
Is there any freeware to do spectrum analysing (FFT) who would work with
that PC parallel port ADC ?
Thank
Gaetan, Canada
scada
If you can save the wave with their software, you can do FFT with
www.dplot.com trial version is free, something like $35 to own it! I
recommend it highly, I've been using it for years!
scada
At a second look at that circuit, the A/D chip has only 8 bit resolution.
That's not going to give you much of an FFT!
Gaetan Mailloux
Hello
How much bit are need to do FFT ?
Thank
Gaetan
scada
Gaetan Mailloux said:
Hello
Thank
Gaetan
The Nyquest theory states you want to sample at a rate of at least twice the
highest frequency you want to see.
Gaetan Mailloux
Hi
Here's what they said at the scope web site;
http://scopeonpc.tripod.com/index.htm
Key Features
Sampling Rate 100K Samples per second
-5 V To +5V Input Range
-50V To +50V Olerload Protection
8 Bit Resolution
Scope Timebases:100uS/Div To 100mS/Div
Scope Volts/Div: 100mV/Div To 5V/Div
Works with ANY parallel port
Thank
Gaetan
jcomeau_ictx
Here's what they said at the scope web site;http://scopeonpc.tripod.com/index.htm
Key Features
8 Bit Resolution
So, a 50 KHz Nyquist frequency. A little better than twice what you
get from the input port of your sound card, at much lower resolution
(16 bits is 256 times the resolution of 8 bits, and 16 bit sound cards
are commonplace). In Canada, as in the US, you ought to be able to
find analog oscilloscopes for $50 or less at yard sales or eBay; that
might be a better use of your money.
I've used the input port of a sound card as a low-frequency digital
scope. It worked, for example, to see the encoding on the magstripe of
a credit card, by hooking up the read-head of an old tape player to
the microphone port of my computer and dragging the card across it.
This was years ago, and I had to write my own software. Nowadays you
have freeware like Audacity that will do that part for you.
Gaetan Mailloux
Hello
I mostly want to do spectrum analysing of distortion, I have a sine wave
oscillator who have less than .0003 % distortions. Most soundcard do
have quite high distortion to do that with a software, and buying a spectrum
analyser adaptor for an oscilloscope cost quite to much for me.
Thank
Gaetan
John Bordynuik
John Bordynuik cut and paste " I mostly want to do spectrum analysing of
distortion"
Hello Gaetan,
Consider using fast ADCs (>20 Mhz ADS1610 or something), parallel
interface or differential, then capture the data on the PC using an
inexpensive (but fast) PCI DIO card. This solution would cost you less than
$600.00 if you built it yourself.
I just finished a 128-channel unit.
Regards,
John Bordynuik
CPU Architect
JBI
Jean-Yves
I'm afraid you wont be able to detect such distortion with equipment
that is less than $20000....
